Changed OFA O ring - JeepForum.com
post #1 of 8 Old 02-14-2011, 07:26 AM Thread Starter
justanotherjpr
Changed OFA O ring
I changed the oil filter adapter O ring this weekend. Usually I can put a standard length wrench on almost any size bolt and break it free. You can imagine my surprise when I reached up with my right hand and gave my 12mm wrench hell (on the T-60 bit knocked out of the socket) and nothing happened. My shoulder/neck is still sore. From below is not the way to do this on a lifted XJ.
I welded that wrench to a length of steel and slipped a pipe over the steel. Broke the wrench.
Undeterred, I retrieved a 'better' wrench from my tool bag. I was able to put the wrench on the bit from above, and the offset in the wrench made it simple to get to. I slipped my high lift handle over the wrench and broke it free.
It backed out by hand after a few more turns with the wrench. The stock O ring was not broken but was very hard. Changed it and seems that no more leaky.
Moral of the story? This is easy to get to with a 12mm wrench that has some offset, the T-60 bit knocked out of its socket, and a cheater.
http://www.northerntool.com/shop/too...6171_200396171
http://www.northerntool.com/shop/too...3288_200313288
And once again, the most useful tool in the world:
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #2 of 8 Old 02-14-2011, 07:32 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Nice. I need to change mine again, it is leaking like crazy. Hopefully since I did this a few years ago it won't be as hard to get off this time.
xjfever is offline
post #3 of 8 Old 02-14-2011, 07:36 AM Thread Starter
justanotherjpr
I bought four O rings so I could change it again if needed. Did you change the inner rings on the bolt, or just the big one?
post #4 of 8 Old 02-14-2011, 07:46 AM
adkjeepxj
I need to do this very soon
adkjeepxj is offline
post #5 of 8 Old 02-14-2011, 07:51 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I changed them all about three or four years ago. The replacements must have not been the same quality as the originals, or I didn't get it torqued back correctly since it is leaking again. My rear main is leaking, oil filter adapter o-rings are leaking and the oil pan is leaking. I have been putting it off until the weather got better and I had the money to replace all of these and the header and exhaust. Hopefully in a few weeks I can get all this done.
xjfever is offline
post #6 of 8 Old 02-14-2011, 09:48 AM
severous01
severous01's Avatar
that's where snapon and matco come in handy... much better quality than 'china' brand or craftsman...
severous01 is offline
post #7 of 8 Old 02-14-2011, 10:13 AM
Hussler
1992 XJ Cherokee
My 92 doesnt leak a drop, all original seals.
My 95 leaked, different design filter adapter though
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #8 of 8 Old 02-14-2011, 01:54 PM
Ben
I did all three a few years back too, they've held up well, but I need to do the VC and rear main now.
The craftsman has a little set screw holding the torx end to the socket body, so you can just pop it right out & back in no sweat. Comes in a kit though, that's hella expensive.
Ben is online now
D-ring to D-ring hook up Dang12457 XJ/MJ Cherokee Non-Technical Forum 6 10-05-2010 03:10 PM
What has been changed in this pic? tahoevicxj XJ/MJ Cherokee Non-Technical Forum 26 03-02-2010 05:08 PM
Changed my CPS but.... carenza XJ Cherokee Technical Forum 3 04-19-2009 09:53 AM
231j ring gear moved out popped snap ring justthefacts XJ Cherokee Technical Forum 0 01-25-2009 12:43 AM
Just changed the TPS... RamboPants XJ Cherokee Technical Forum 8 07-21-2007 04:30 PM
