center pin/cross shaft wont go back in - JeepForum.com
post #1 of 5 Old 02-23-2008, 12:19 PM Thread Starter
gradysjeep
gradysjeep's Avatar
Have a friend putting 456 gears in my 8.25 and while putting it back together he found that the center pin doesnt have enough clearance to go back in. Are you suppose to file down the ring gear teeth on these to get the center pin back in and if so how much can you take off and still be ok.
gradysjeep is offline
post #2 of 5 Old 02-23-2008, 12:25 PM
badassls1z
badassls1z's Avatar
When I put the Aussie locker in my D30, I had to put the pin in before I put the ring gear back on the carrier. I didn't feel comfortable filing teeth down. So if I am understanding you right you already have the carrier back in the housing? If so I would take it back out, take the ring gear off and put the pin in. Just my
'06 Wrangler X, 4.0 Auto, 31" Kumho MT's on Black Cragar v-5's
'92 White XJ Laredo, 3" Lift, 33's SOLD
badassls1z is offline
post #3 of 5 Old 02-23-2008, 12:26 PM
XJohnnyC
XJohnnyC's Avatar
XJohnnyC is offline
post #4 of 5 Old 02-23-2008, 12:29 PM
XJohnnyC
XJohnnyC's Avatar
Can't do that on an 8.25 because of the c-clips.
You either have to shave the pin or grind a tooth.
XJohnnyC is offline
post #5 of 5 Old 02-23-2008, 12:34 PM Thread Starter
gradysjeep
gradysjeep's Avatar
Hey thanks thats what we are going to do. I went over to naxja and found that thread after posting.
sprayed painted my center console, the lid wont dry!! Scott4589 XJ Cherokee Technical Forum 5 02-18-2009 05:51 PM
8.25 pinion shaft cross pin mikochan XJ Cherokee Technical Forum 1 09-03-2007 08:47 PM
track bar wont go back in? ridebmx4140 XJ Cherokee Technical Forum 3 06-08-2007 02:22 PM
Retaining bolt for cross shaft, d35? Alexia XJ Cherokee Technical Forum 7 12-10-2005 12:19 AM
Rounded Cross Shaft Bolt TheBandit181 XJ Cherokee Technical Forum 5 08-25-2005 02:13 PM
