Quantcast cb Radio antenna - JeepForum.com
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > cb Radio antenna
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineONBOARD-AIR.COM: Economy OBA System**Best prices on Yukon Axle & Gears**
JeepForum Membership Drive - Reduced Premium Membership For a Short Time Only
Old 11-16-2009, 09:56 PM   #1
rdeveau2005
1993 XJ Cherokee
cb Radio antenna
Im going to mount my cb radio antenna next to the tailight and i was wondering what type on antenna should i get and how long. and if you know of any companies that make them that would be great. I have a cobra cb radio.
rdeveau2005 is offline   Reply With Quote
Old 11-16-2009, 10:28 PM   #2
rivalarrival
Stormaggedon
rivalarrival's Avatar
All of the whips are basically the same thing - a coil of copper wire wrapped around a fiberglass rod and covered in a heavy-duty, heat-shrink wrapper. Most are loosely wound at the bottom and tightly wound at the top, to push most of the signal out above the cab of the vehicle. They all function the same way, and are all going to be about as efficient. Basically, the longer the rod, the the more effective the antenna. There are two basic lengths, one about 18", and another about 36". The antenna should have at least 1/2 or 2/3 of its length above the cab.
There is another type that you'll see occasionally: a spring-steel whip about 9-feet tall. IMHO, they are more trouble than they are worth.
Fiberglass whips are pretty cheap: $10-$20 in most cases.
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself. --Thomas Paine
We work together every damn day. --Jon Stewart
Any gas can be a knockout gas, when you wrap a steel cylinder around it and beat someone with it.
Low Output 4 Cylinder Jeep Club member #188
rivalarrival is offline   Reply With Quote
Old 11-17-2009, 12:08 AM   #3
tizzdizz
2003 WJ
I have a 4' antenna from Radio Shack, and I used a spring and mount that I found at Fry's Electronics. It works great off road, but I don't get a lot of range on the freeways. Can't pick up too many truckers. I you might try yours out at different heights before deciding on a location, so that you can get the best reception. You also need to tune it with an SWR meter, and make sure you have the mount set up right so that it's grounded correctly. Here's a pic of my mount, and how I mounted the radio itself.
03 WJ Limited, 4" Zone, 265/75/16 Goodyear Wrangler Duratracs
89 XJ Pioneer: Stock with 31s and a trim. Sold
99 XJ Sport: 2" on 31s with armor and dents. Sold
74 Nova - 2" drop and disc conv. Sold.
My videos
tizzdizz is offline   Reply With Quote
Old 11-17-2009, 12:11 AM   #4
rdeveau2005
1993 XJ Cherokee
well maybe i should mount it on the bumper cus if i mount it with the taillight cant it damage the taillight if my antenna gets hung up on somethig?
Old 11-17-2009, 12:23 AM   #5
tizzdizz
2003 WJ
Well, Yeah I wouldn't mount it TO the tail light, but some people use the bolts that hold the tail light housing to the body. To be fair, mine rubs on the trunk when I open it but it's not bad and doesn't bother me. I'd rather it be behind the jeep though, than on the side where it can get caught on a tree or the side of a hill or gulley.
Here's an option. Motion Offroad XJ Cherokee CB Antenna Mount - 1984-96 [MO2.5001] - $45.00 : MotionOffroad.com, Innovative Offroad Products
Another idea, even though it's a ZJ, it could still work. Tomasz Korwel CB antenna mount in Grand Cherokee :: programmer, administrator, engineer - my everyday fights with reality
My videos
Old 11-17-2009, 01:33 AM   #6
rdeveau2005
1993 XJ Cherokee
yea not on the tail light but inbetween the housing and the body. thanks for the websites
Old 11-17-2009, 02:00 AM   #7
Wiskey
1991 XJ Cherokee
I just got a little magnet mount job and stuck it on my roof.
It's not nearly as cool, but I ran the wire nicely, and if I hit a tree with it, the antenna doesn't break, it just flops over, and I stick it back on. The antenna was around $20 at Walmart, I've had it up to about 85 on the freeway without it falling off.
Whiskey
[QUOTE=Rescue XJ;1414400]Seafoam. . . Its the closest thing to an enema for your engine.[/QUOTE]
Wiskey is offline   Reply With Quote
Glock Forum
