cb antenna mount - JeepForum.com
 1Likes
post #1 of 20 Old 02-11-2017, 05:35 PM Thread Starter
barbaraw
cb antenna mount
Im trying to find out if the cb antenna mount fire stick mk174 will work on my hood,I have a 96 cherokee Thanks for any help
barbaraw is offline
post #2 of 20 Old 02-11-2017, 05:38 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The FireStik MK-174 hood mount works well on XJ Cherokees.
CJ7-Tim is offline
post #3 of 20 Old 02-11-2017, 05:51 PM Thread Starter
barbaraw
great thanks so much for the help
barbaraw is offline
post #4 of 20 Old 02-11-2017, 06:27 PM
YY5RM
1988 MJ Comanche
Hi Engineer Barbaraw, nice to meet you, I'm writing from Venezuela.
If you want to check if the antenna emits well, you can use an SWR meter instrument, but have the RFS (RF Signal) position on the selector. They are recognized because they have a small antenna.
sube fotos
The test consists of mounting the antenna in different parts of the car, when transmitting it should simply move 360 degrees around the antenna with the instrument in hand (without connecting to anything) and with the RF reading given by the instrument you can check where and To where it emits better signal strength.
If you are using original cable extension, it is advisable to use resonant coaxial cable to prevent the antenna from moving its bandwidth to other unwanted frequencies.
For my part, welcome to the forum and I am at your service (QRV).
zrickety likes this.
YY5RM is offline
post #5 of 20 Old 02-11-2017, 08:48 PM
NT7B
1986 XJ Cherokee
YY5RM? I see I'm not the only one here using their callsign as a forum ID. Nothing really to add to the thread, just wanted to say 73 from another Amateur, de NT7B.
NT7B is offline
post #6 of 20 Old 02-12-2017, 04:45 AM
YY5RM
1988 MJ Comanche
Specials greetings colleague Jeffrey, these days there is no good atmospheric spread but hopefully I can copy it one day to exchange comments.
I'm glad to hear that I have Radio Amateurs here.
The following file has a lot in common with the answer I gave in this post:
https://files.acrobat.com/a/preview/...5-cc7ac5ac61b2
I know that Jeepforum.com is for Jeep cars and it is of little relevance to comment on radios. For those who require it, on my page www.qrz.com/db/YY5RM there are similar files dedicated to knowledge of electronics, radios, antennas and construction at low costs (Currently translating into English).
YY5RM is offline
post #7 of 20 Old 02-19-2017, 02:43 PM Thread Starter
barbaraw
hi everybody I got the antenna installed on my hood and the cb radio installed but I have a lot of coax that I round up it was an 18 foot cable and Im only using maybe 5 feet of it , can I cut that much off ?
barbaraw is offline
post #8 of 20 Old 02-19-2017, 03:57 PM Thread Starter
barbaraw
hi can you tell me if I can cut some of the coax off for my antenna. I have it hooked up but i git 18 feet and Im only using maybe 5 feet !Thanks
Barbara
barbaraw is offline
post #9 of 20 Old 02-19-2017, 05:01 PM
CJ7-Tim
CJ7-Tim's Avatar
Yes, you can use any length of coax cable as necessary. If the coax cable terminates in bare wires you can trim it down. If antenna end of the cable has a connector installed, unless you are skilled at installing them, you should leave it alone. Simply bunch up any excess coax cable and zip tie it out of the way.
CJ7-Tim is offline
post #10 of 20 Old 02-19-2017, 07:44 PM
YY5RM
1988 MJ Comanche
The SWR is inevitably in CB for cars, this is the effect when trimming the length of the coaxial cable:
subir imagen
It simply shifts the resonance frequency, ie the best response of your antenna moves to another frequency or channel. If it is very important, simply adjust the antenna.
QRV.
YY5RM is offline
post #11 of 20 Old 02-20-2017, 09:45 AM Thread Starter
barbaraw
thanks
Barbara
barbaraw is offline
post #12 of 20 Old 03-19-2017, 05:09 PM Thread Starter
barbaraw
Is there anybody in chino valley az than can tune my antenna thanks
barbaraw is offline
post #13 of 20 Old 03-23-2017, 05:53 PM
KF4SQB
1994 XJ Cherokee
It can get to be a pretty involved subject, but the "short answer" is that you should not shorten the coax, if possible. Running the "wrong" length can cause false readings from an SWR meter, and make correctly tuning the antenna impossible. Just keep in mind that you should NOT! under any circumstance "coil" the coax. Instead, "bundle it up", and use cable ties or tape to keep it in position. Also, you should check to make sure that your hood is properly grounded. A braided strap is the best bet to ground it for RF purposes.
NT7B, no, you're not the only person using their callsign for a usename! 73s to yourself, and YY5RM, from South Georgia!
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #14 of 20 Old 03-24-2017, 10:18 AM
YY5RM
1988 MJ Comanche
Greetings to all.
Hi Ryan Colleague, nice to meet you. I hope to copy it one day in frequency.
For the signal to go far, it is best to install it in a place of the car, avoiding proximity to the metal of the body. Many people prefer not to drill holes in the body, could be in the roof rack.
Here are some of the cars we've had at home:
subirimagenes
The car I use most is the Comanche, the antenna is installed in the corner of the cargo box.
subir fotos online
QRV.
YY5RM is offline
post #15 of 20 Old 03-24-2017, 11:23 AM
CJ7-Tim
CJ7-Tim's Avatar
The length of coax has no effect on the antenna system performance (radio, coax & antenna) in radiating the energy at the antenna, and also has no effect on the tuning of the antenna itself. If your antenna is properly resonant, and the feedpoint impedance is close to the feedline impedance, the length of the coax will not make one bit of difference.
Good info here >> http://www.stu-offroad.com/misc/myth-1.htm
CJ7-Tim is offline
