cb antenna cut - JeepForum.com
post #1 of 18 Old 02-16-2006, 08:25 PM Thread Starter
charlie_merrifi
cb antenna cut
is it ok to cut a cb antenna then splice it back together? how will this affect everything
1989 Cherokee Pioneer. I6 4.0 dana 35 rear (no laughing)
Cheap 1 inch lift (shackles and spacers) Walmart Light mod w/100 watt bulbs on bumper (no roof rack), 235/75/r15 YKS traction tires, Pinoeer Stereo, Kenwood 5.25 speakers all around
2 12 inch Rockford punch subs
Cheap 4oo watt amp
Future mods
quick disconnects
front hitch
Lift
Winch
charlie_merrifi is offline
post #2 of 18 Old 02-16-2006, 08:39 PM
creature
creature's Avatar
....Cutting the antenna? By any chance do you mean the coax cable?
-Shawn
creature is offline
post #3 of 18 Old 02-16-2006, 08:52 PM
RuggedJeep
I wouldnt cut either..
97XJ D30/Truhi9, Alloys, 36's, Beadlocked, Caged.
RuggedJeep is offline
post #4 of 18 Old 02-16-2006, 08:57 PM
anony91xj
Neither would I...
1998 VW GTI 2.0
anony91xj is offline
post #5 of 18 Old 02-16-2006, 09:42 PM Thread Starter
charlie_merrifi
yeah i mean the cable. dont really have any other choice
Cheap 4oo watt amp
Future mods
quick disconnects
front hitch
Lift
Winch
post #6 of 18 Old 02-16-2006, 09:53 PM
creature
creature's Avatar
What do you mean "no other choice"? We can possibly help you with routing the cable a better way.
-Shawn
creature is offline
post #7 of 18 Old 02-16-2006, 09:55 PM Thread Starter
charlie_merrifi
well i want it up front but have no wat to run it through the rubber gromet on the firewall i got too much stuff there as it is. and I tried for about an hour and couldnt get the damn ends through thats why i thought about cutting it and pussing it through the other side i can get aa single wire through it but not with the connectors on the ends. what harm would cutting it and splicing it do. I wont use the cb a ton.
Cheap 4oo watt amp
Future mods
quick disconnects
front hitch
Lift
Winch
post #8 of 18 Old 02-16-2006, 10:40 PM
FlatlineCowboy
FlatlineCowboy's Avatar
drill a bigger hole?
I wouldn't cut the end off of it, it may cause interference in the cb.
** ask stu **
White Jeep Club Member #513
2002 Jeep Wrangler Sahara Edition
White / Spice
4.0L, Auto, Soft top, D30-F / D35-R
30x9.50x15 Wrangler GSA
(4) 100watt driving lights & (4) 55watt reverse lights
Silverstar headlights & paint bezels black
FlatlineCowboy is offline
post #9 of 18 Old 02-16-2006, 10:42 PM Thread Starter
charlie_merrifi
I had it hooked up to see if it works. Is it bad that the meter on the cb goes to the red when I key it how do i fix this
Cheap 4oo watt amp
Future mods
quick disconnects
front hitch
Lift
Winch
post #10 of 18 Old 02-16-2006, 10:44 PM
mud-dog27
there should be two holes in your firewall theres the small rubber grommet then in mine i got a bigger hole that had a plug that i happened to lose and even if you dont have that hole cut a new hole i will try and get pictures tomorrow...its supposed to go into the red
89 wagoneer LTD. , 32x11.5R15 wild country RVT, 15x8 AR baja rims , surco safari roofrack w/spare tire kit , cobra 19 DXIII w/ high gear mic. 4' whip on a 3" heavy-duty spring , 4.5" rough country full leaf pack lift kit
mud-dog27 is offline
post #11 of 18 Old 02-16-2006, 10:46 PM
creature
creature's Avatar
Depends on what the meter is for.....and DON'T key the mic with out the antenna connected.
-Shawn
creature is offline
post #12 of 18 Old 02-16-2006, 11:16 PM
cmotsvt
If you have to cut it I'd say put a mini-connecter on the end of the coax from the antenna, then put a mini on the end of the coax to the radio. If youre not experiences with coax you may want to have a pro do the connectors so you know its done right.
cmotsvt is offline
post #13 of 18 Old 02-16-2006, 11:18 PM Thread Starter
charlie_merrifi
all the meter says is power meter?
Cheap 4oo watt amp
Future mods
quick disconnects
front hitch
Lift
Winch
post #14 of 18 Old 02-16-2006, 11:19 PM
dynamite44
you don't have to run it through the firewall. open up one of the front doors, put the wire where the hinge is. run it through the interior of the fender into the engine compartment.
the gasket material used to seal the doors of XJs is so thick you won't have a problem with whistling.
2000 XJ silverstone metallic.
dynamite44 is offline
post #15 of 18 Old 02-16-2006, 11:20 PM
mww1962
Junior Member
Cable cutting
There is no problem cutting the antenna cable. The important part is how you go about spling it back together when you finished routing it. The only acceptable way I can think of is to buy a couple BNC connectors and a BNC coupler. Try and find a local amateur radio shop in your area, or even a HAM club - they will be most familiar with this. Simple if you have some electronics skills.
Keying the Mic without an antenna load could harm the radio.
Mike.
mww1962 is offline
what antenna? jebidiah XJ/MJ Cherokee Non-Technical Forum 1 11-18-2009 06:38 AM
help with antenna lk123 XJ Cherokee Technical Forum 0 09-17-2009 02:20 PM
CB antenna Kieffer87 XJ Cherokee Technical Forum 39 01-13-2008 11:59 PM
turn of antenna motor, but leave antenna up? XmuthJ XJ Cherokee Technical Forum 11 03-27-2007 03:55 PM
CB Antenna drewguere XJ Cherokee Technical Forum 13 10-09-2006 12:02 AM
