CB Antenna - JeepForum.com
post #1 of 14 Old 10-06-2006, 10:38 PM Thread Starter
drewguere
drewguere's Avatar
CB Antenna
Im looking to mount a CB antenna from the taillight. Does someone make a braket for this or do I have to custom do one?
2002 GMC 2500HD 8.1L - Tow Rig
1998 Jeep Cherokee - Wheelin Rig
1988 Jeep Wrangler - In progress...
drewguere is offline
post #2 of 14 Old 10-07-2006, 12:06 AM
madrabbitt
madrabbitt's Avatar
Theres a mount that will sorta work for your requirements.
Heres one store that has it.
http://www.www.premiere-electronics....re/ss204a.html
BTW. i need to join your club.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #3 of 14 Old 10-07-2006, 01:48 AM
jeeptorino68
1992 XJ Cherokee
ya how do i joint aht club too, cant help on the antenna tho, i have a hood mount
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #4 of 14 Old 10-07-2006, 07:18 AM
mpwal099
mpwal099's Avatar
1997 XJ Cherokee
This is what I have. I went to the local cb shop and it was in the clearance bin for $2. I did have to drill out a moutniing hole on it, but it works great.
When I die and go to heaven I hope the first thing God says to me is "The bar is right this way."
mpwal099 is offline
post #5 of 14 Old 10-07-2006, 07:59 AM
BigBearXJ
It mounts to all 3 taillight bolts.
BTW, I also need in your club.
Eat, Jeep and be Merry.
BigBearXJ is offline
post #6 of 14 Old 10-07-2006, 07:50 PM
madrabbitt
madrabbitt's Avatar
hm. alot of eagles out here.
Did you start a club thread already? so we can start picking our numbers.
post #7 of 14 Old 10-07-2006, 08:15 PM
cocoloco
have you check the SWR?
it looks like you have a insulation washer on the bottom.there should not be one on the bottom because thats where you get you ground from.
whoops i just noticed the ground wire,my bad
98 cherokee, automatic, 4.5RE rear springs,6inch skyjacker front coils. TnT long arm ,33 procomp MT .AA SYE with front drive shaft.6 degree shims. bilstein 5150 12inch .JKS BPE .NE, OH.
cocoloco is offline
post #8 of 14 Old 10-07-2006, 09:36 PM
madrabbitt
madrabbitt's Avatar
someone smack me.
thats why i cant get the damn swr any lower on mine...
post #9 of 14 Old 10-07-2006, 11:05 PM
wolfepack215
wolfepack215's Avatar
1987 XJ Cherokee
Best Mount Option By Far.......
wolfepack215 is offline
post #10 of 14 Old 10-07-2006, 11:14 PM
madrabbitt
madrabbitt's Avatar
yeah. i saw that AFTER i drilled mine... Oh well.
post #11 of 14 Old 10-08-2006, 09:36 AM
white98xj
white98xj's Avatar
http://www.walcottcb.com/k40-trunk-m...nna-p-396.html
thats what im getting today
but it wont go on the tail light
1998 Jeep Cherokee, OME Lift, Loud Exhaust...
white98xj is offline
post #12 of 14 Old 10-08-2006, 04:36 PM
YMMV
That is the one I used as well.
YMMV is offline
post #13 of 14 Old 10-08-2006, 06:30 PM
snowblur17
snowblur17's Avatar
1993 XJ Cherokee
Well if you do any woods wheelin, then this mount isn't so great.....at least not with a 5 footer, mine is currently dangling off of the one tailight mount, all other screws have been torn out of their holes. I'm gonna go with a hood Mounts because I was told that a firestick needs something flat to reflect off of (roof or hood on an XJ), and since I don't want 5 feet of firestick on my roof, hood it is.
'93 XJ. Crusty's 3"
bet you haven't heard of them 31" MTs
tcase skidage, and some other do-dads
snowblur17 is offline
post #14 of 14 Old 10-08-2006, 11:02 PM
wolfepack215
1987 XJ Cherokee
I was just about to point out that should you choose this mount..... You must throw away the screws that come with it and get some stainless bolts/washers/nuts and do it correctly so it won't tear out the first time you smacka a limb. Use the dime size washers if you can find them for better support behind the sheetmetal..... Ive had mine out 3 times now on trails that are literally too small for ATV's and have had no problems with it as it is bolted in and not screwed. Because if you use screws, you will be screwed!!
what antenna? jebidiah XJ/MJ Cherokee Non-Technical Forum 1 11-18-2009 05:38 AM
help with antenna lk123 XJ Cherokee Technical Forum 0 09-17-2009 01:20 PM
CB antenna Kieffer87 XJ Cherokee Technical Forum 39 01-13-2008 10:59 PM
turn of antenna motor, but leave antenna up? XmuthJ XJ Cherokee Technical Forum 11 03-27-2007 02:55 PM
cb antenna cut charlie_merrifi XJ Cherokee Technical Forum 17 02-16-2006 11:20 PM
