Quantcast Is this caused by a bad O2 sensor? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Is this caused by a bad O2 sensor?
Old 11-27-2006, 10:54 AM   #1
firehawk
First of all the Jeep drives fine. Only when I have driven awhile, and the engine is at normal operating temperature do I have a problem. It dosen't do it all the time, but is becoming more frequent.
After a long drive, or sitting and idling for awhile if I shut the engine off, and when I restart it it seems to be running on 3 cylinders. Once I liked to never get it to start, but only once... so far. When I can get the rev's up it seems to clear itself out and it runs fine until the next time I shut it down after a long drive, or extended idling.
It has set no codes that I'm aware of. Just curious as to what is causing this before I spend some change on O2 sensors. MAN they are proud of them, WheW!
2000 Cherokee Sport
Patriot Blue
4.0L / AW4 / NP 242, blah, blah, blah...
A lot of parts that cost a lot of money
xjTalk.com
firehawk is offline   Reply With Quote
Old 11-27-2006, 11:24 AM   #2
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
No. this is a common problem with 00 and 01 XJ's with the distributorless ignition. What's happening is one of the FI's is getting heat soaked and causing a missfire. There is a TSB out on it, to replace a heat sheild to combat the problem... If you do a search there is a lot of info on it.
Kyle - I tag stuff®
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline   Reply With Quote
Old 11-27-2006, 11:33 AM   #3
firehawk
Thanks for the info! I'll start looking into it.
2000 Cherokee Sport
Patriot Blue
xjTalk.com
Old 11-27-2006, 12:40 PM   #4
XxpeditionxJ
Take your Jeep to the local Jeep Dealer and they will install the heat shield for free with no questions asked.
[COLOR="Blue"][COLOR="Red"]Flame Red [/COLOR]2000 Jeep XJ. I6-4.0 Powertec. Dana 30 FE. Chrysl 8.25 RE. NP231 xfer. 245x75x16 on Rubicon Wheels. K&N Cold Air Intake. Magnaflow High Performance Cat. Flowmaster 40 Series. Stuff..[/COLOR]
XxpeditionxJ is offline   Reply With Quote
Old 11-28-2006, 02:25 AM   #5
shierkahn
I'm having this same problem but, mine's a '92. Still trying to figure it out.
'92 XJ, 4" Shade-tree lift
33/12.50's, 15x8 Soft 8's/4"BS
D30ft, D44rr, 3.55 gears
[SIZE="4"][FONT="Arial Black"]!!GOT MUD!![/FONT][/SIZE]
[url]http://s107.photobucket.com/albums/m309/shierkahn/[/url]
shierkahn is offline   Reply With Quote
Old 11-29-2006, 11:33 AM   #6
firehawk
Well went down to my friendly Jeep dealer and this is what I learned. Oh BTW they WON'T supply the part OR install it for free. It cost me $8.07.
__________________________________________________ _______________
Service Bulletin #18-031-03 Dated 9/5/03
Subject: 4.0L Rough Engine Idle After Restart Following a Hot Soak
Overview: This bulletin involves the installation of a fuel injector insulator sleeve.
Models:
'00-'04 TJ
'99-'04 WJ
'01-'04 WG
'00-'01 XJ
Applies to vehicles equipped with a 4.0L engine (sales code=ERH)
Basicly is says 20-30 seconds of rough idle after a restart in hot 90* or higher.
" This condition may be caused by heat from the exhaust manifold that following engine shut down migrates to the area around injector #3 and cause a fuel vapor to form within the injector. This in turn may cause a momentary misfire of cylinder #3 until the fuel vapor is cleared of injector #3. The insulator sleeve lowers the injector temperture to a point below which the fuel will not normally vaporize."
Insulator sleeve part #56028371AA Ignition Wire Shield
It says this part will make 2 injector insulator sleeves.
Another Service Bulletin # 18-039-03 involves reprogramming the PCM to lower the temperture at which the electric fan kicks on. My past experience with reprogramming a PCM was a cluster f**k to say the least. It cut the MPG of the '96 Dakota I had by 6-8 mpg. So I'll leave this one as a last resort.
Hope this helps anyone else that has this problem.
2000 Cherokee Sport
Patriot Blue
xjTalk.com
Old 11-29-2006, 12:17 PM   #7
toledotimber
Right. TSBs aren't recalls and the dealership gets to decide if they'll cover them or not (generally not).
toledotimber is offline   Reply With Quote
Old 11-29-2006, 03:41 PM   #8
huntsvil
My 96 has a similar prob too. After idle awhile it starts to stall when I take off. I see this is beginning to be a common thread. Will be watching.
huntsvil is offline   Reply With Quote
Old 11-29-2006, 03:45 PM   #9
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
This is going to be a different problem. Your ignition system is totally different than an 00-01.
Kyle - I tag stuff®
Glock Forum
