Is catalytic converter necessary for 99 xj to run right? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Is catalytic converter necessary for 99 xj to run right?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 04-02-2008, 05:45 PM   #1
gafuller01
I have a 99 XJ 4x4 4.0L. Will the engine run right with no catalytic convertor? Also, will the absence of a CC affect the O2 sensors?
gafuller01 is offline   Reply With Quote
Unread 04-02-2008, 06:03 PM   #2
1996xj
Yes it will run. The downstream O2 sensor will light the check engine light if you remove the cat.
1996xj
3" Rough Country Lift, 3in shackles, 3 RC shocks, 31" BFG ATs, 2 KCs, Lighted Roofrack, Soft 8s, TC drop, Custom oil leak deflector.
If only i could get a set of tires to last me 10,000Miles
Originally Posted by toates89
i am just gunna drive around in 4lo on dry streets, and peel out
Originally Posted by 4.0H.O.XJ
I once got a ticket for jerking while driving it. The cop wouldnt let me use his pen to sign the ticket.
1996xj is offline   Reply With Quote
Unread 04-02-2008, 06:48 PM   #3
Paybac
No worries
I should run sweet and actually give you a bit of extra power. Maybe on the verge of being noticable maybe even a bit of extra MPG. I havn't done it on a jeep but you should just be able to ground that sensor on the body somewhere. That will stop the check light.
Paybac is offline   Reply With Quote
Unread 04-02-2008, 07:04 PM   #4
rstarch345
It is against Federal law to remove a catalytic converter.
You aid tree huggers in their fight about us contributing to environmental damage.
You might gain 1/2 MPG per tank of gas.
Be a smart Jeeper and keep the cat in and let my grand kids have good air to breath.
Full Specs
2K XJ - 6" lift w/ 34s
'98 XJ Laredo - Stock (and staying that way)
'71 M151
I'm a proud member of MyUniBody
rstarch345 is offline   Reply With Quote
Unread 04-02-2008, 07:19 PM   #5
geewally9
I bought my 98 with no cat and the O2 sensor is cut but my light isn't on. Oh well haha. The cat just gets clogged and kills your jeep.
geewally9 is offline   Reply With Quote
Unread 04-02-2008, 07:26 PM   #6
xjarchaeologist
Yes, it will run right, but that doesn't mean you should do it.
xjarchaeologist is offline   Reply With Quote
Unread 04-02-2008, 08:14 PM   #7
cherokeeman90
theres things you can buy to make it sound like you dont have a cat
but yes, plz don't do it for all our sake...
cherokeeman90 is offline   Reply With Quote
Unread 04-02-2008, 08:17 PM   #8
nujeepguy
1997 XJ Cherokee
you know when i was young and stupid and childless I removed cats whenever i could. i didn't know the environment pays for it dearly. They way I look at it now is how would you feel if the air you breathe smelt like rotten farts and the water tasted like where those farts came from. Our kids ,kids will probably find out. I don't want to knowingly be the sh%$5 flinger.
nujeepguy is offline   Reply With Quote
Unread 04-02-2008, 08:28 PM   #9
lgnd6
It will more than likely sound terrible too...especially if you have aftermarket exhaust.
Just get a high-flow cat.
Magna-Flow makes a good one.
Your exhaust only needs to flow as much air (cfm) as your engine combination is anyway. So unless you have forced induction or large displacement with a super good flowing head and other internal mods, you won't notice much of a difference in a high-flow cat versus no cat. Plus the high-flow ones are legal. You might see a couple horsepower by replacing the stock with a high flow...and maybe one more hp by no cat at all.
lgnd6 is offline   Reply With Quote
Unread 04-02-2008, 08:31 PM   #10
ktmracer419
1997 XJ Cherokee
just keep the cat
/ thread
97 xj
44 front, detroit, alloyed
60 rear, detroit, 35 spline alloyed
35" beadlocked km2's
3" midarmed
more bells and whistles than you can shake a stick at
ktmracer419 is offline   Reply With Quote
Unread 04-02-2008, 08:32 PM   #11
XJKyle1389
aCTUALLY IT WILL HURT UR FUEL MILEAGE AND THE XJ WILL RUN BADLY. THE O2 WILL LIGHT THE CHECK ENGINE LIGHT AND THE SYSTEM WILL NEVER GO INTO CLOSEED LOOP. wITHOUT CLOSED LOOP, YOULL BE RUNNING REALLY RICH EXHAUST. nOT TO MENTION WHEN THE COMPUTER THROWS A P0300 CODE (CATALYTIC CONVERTER INEFFICIENCY) IT WILL TRY TO COMPENSATE AND REALLY PLAY WITH UR AIR FUEL MIXTURE BADLY MAKING A ROUGH RUNNING XJ.
XJKyle1389 is offline   Reply With Quote
Unread 04-02-2008, 08:35 PM   #12
XJLI
1993 XJ Cherokee
no it wont. you are wrong.
Factory Four Link
XJLI is offline   Reply With Quote
Unread 04-02-2008, 08:37 PM   #13
ktmracer419
1997 XJ Cherokee
thats for the primary 02
the after cat 02 will(should) set off a code and tell you to replace your cat convoytah
97 xj
3" midarmed
Unread 04-02-2008, 08:52 PM   #14
1996xj
The are some ppl that shouldnt be giving advice....
1996xj
Unread 04-03-2008, 02:03 AM   #15
xjcowboy01
I concure. If youre not absolutely possitive then tell us it is just a guess. We dont need to lead people into doing things that may hurt them or their jeep in the long run. Oh by the way I beleive the computer on the 99 is complex enough that even if a cat didnt have an O2 sensor in it the upstream O2 sensors may notice a difference and cause the jeep to get squirley. I dont beleive that there is much to gain by removing it and possibly much more to lose. So the safe bet would be leave it or get a high flow cat.
Live for those who have died for your freedom.
xjcowboy01 is offline   Reply With Quote
