Catalytic converter - JeepForum.com
post #1 of 12 Old 06-06-2013, 12:12 PM Thread Starter
LiveforXJ
Catalytic converter
Shop said that my catalytic converter is bad, any ideas on where or what I should do? Should I go to the junk yard or what?
LiveforXJ is offline
post #2 of 12 Old 06-06-2013, 12:15 PM
chriskeenan
what makes you think they are right? Could they just be making stuff up or is there a legit reason?
Also new "high flow" cats are ~80$ if you look around, skip the junkyard ones.
chriskeenan is offline
post #3 of 12 Old 06-06-2013, 12:25 PM Thread Starter
LiveforXJ
They estimated 2000 for a new one, is it easy to fix or will the shop have to do it?
post #4 of 12 Old 06-06-2013, 12:29 PM
chriskeenan
2000 what? I certainly hope not dollars, cause that price is ridiculous. One if not two whole new exhaust systems, from header to tail pipe, could be put in for that price.
Its easy to do, drop the exhaust (45 minutes with hand tools), cut off old cat (5min with saws-all), weld in new cat (5min with welder), and reattach.
But still are you sure its even necessary to replace the cat?
post #5 of 12 Old 06-06-2013, 12:46 PM Thread Starter
LiveforXJ
Well they said the cat is bad, and the idle motor, I just got an new engine 3 days ago and now it's shutting off at stop lights and they said those 2 things are what's wrong
post #6 of 12 Old 06-06-2013, 12:59 PM
chriskeenan
The IAC (idle air control) valve is a 40$ part that takes one tool and 2 minutes to change, start with that.
I seriously doubt the cat is bad. If its plugged up the engine will refuse to rev beyond a certain point, the engine will seem to have no power, the exhaust manifold and pipes with get so hot it will glow red, engine will have very little vacuum, high exhaust pressures. if the catalyst inside simply worn out all it will do is trip the CEL light on the dash. And unless the cat sounds like its full of rocks or marbles when shaken or hit, the cat is fine.
post #7 of 12 Old 06-06-2013, 01:03 PM
Jeep_Tech
x2 take your jeep and run these guys are out for your blood. better yet send me their number and i will curse them out for you. gives good mechanics a bad name
Jeep_Tech is offline
post #8 of 12 Old 06-06-2013, 01:23 PM Thread Starter
LiveforXJ
I mean they are a jeep shop, that's all they do. So it's kinda hard not to trust them but thank you for the tips, I'm definatly not paying 2000 for that.
post #9 of 12 Old 06-06-2013, 02:19 PM
Paradise XJ
1988 MJ Comanche
The "Jeep" shop is not the reason to not trust them.
The "$2000" is. That is just plain ridiculous, if not criminal.
Ask them to book out the labor for you...out of the "book"
A cat might take me an hour to swap out, laying on my back, on a gravel driveway, in the snow.
An IAC would likely take me 5 minutes...underwater.
What's the $2000 for ??
Find a new shop. Go to a muffler shop get a quote, then go to NAPA and buy an IAC.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #10 of 12 Old 06-07-2013, 08:02 AM
playbass
Yeah, I just had my cat replaced and it only cost around 150$. About 80$ for a walker cat and 60$ for the install at a muffler shop.
This is work more suited for a muffler shop, I would go to one of those over a Jeep specific shop (as the later probably has higher rates.)
playbass is offline
post #11 of 12 Old 06-07-2013, 08:38 AM
bobthecatkiller
Performance curve thunderbolt cats are cheap something like $40
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #12 of 12 Old 06-07-2013, 08:51 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
I'll fix it for you for $1,900.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
