Cat converter making noise. - JeepForum.com
post #1 of 9 Old 08-17-2002, 03:49 PM Thread Starter
glennv
glennv's Avatar
I have what I thought was a loose pipe or something. I went to tighten up the exhaust and found that the rattle was coming from inside the cat converter. Any thoughts?
2002 Sport: I6, 4.56 gears, SYE, RE 3.5", 305 BFF MTs.5-spd,d30/d44.
2004 Grand: I6, wife's
1998 XJ: My daily driver. I6
"The Second Amendment is not about duck hunting, and I know I'm not going to make very many friends saying this, but it's about our right, all of our right to be able to protect ourselves from all of you guys up there." - Dr. Suzanna Gratia Hupp, appearing before Representative Charles Schumer's committee hearings on the assault weapons ban
glennv is offline
post #2 of 9 Old 08-17-2002, 07:18 PM
amaple
Your cat has quite a bit a crap inside (mainly ceramic and platinum) and over the years the ceramic will crack and pieces will form. There isn't really anything that you can do to fix it. This is what causes the rattling. Your cat is still working and it is not anything to worry about this minute, but in the end, a piece of this ceramic is going to end up clogging your tailpipe and you will find that your Jeep won't start. I have the same problem and have had it for two years now. I'm just going to gut the converter and put it back on. You can buy a new one if you desire, but they're not cheap.
good luck,
adam.
1993 Cherokee Country ** Rubicon Express 3" Super-Flex lift ** 1.5" Rusty's extended rear shackles ** Rusty's exhaust ** Wilderness Roof Rack ** BFG A/T KO 31's ** Brand new 4.2L engine ---
1974 CJ-5 ** dual Dana 44s ** only 55,000 original miles! ** no mods yet
Adam
amaple is offline
post #3 of 9 Old 08-17-2002, 07:24 PM
arpy
Yep, mine did that until I had it replaced. Unless your year model's cat is different from mine (88), you can use a universal cat. I got one at a parts store, Walker brand, for less than $100 and had it welded in at my local exhaust shop.
arpy is offline
post #4 of 9 Old 08-17-2002, 07:28 PM
arpy
ok, just checked autozone.com for you, I assume its the 93 not the 01 with the problem. They show a direct fit cat for 93 for $129 and a universal for $79
arpy is offline
post #5 of 9 Old 08-17-2002, 08:02 PM
amaple
Though I wasn't the one with the question, thanks. I thought I was looking at $300+ for a new cat so I was going to gut it. I didn't even know that there were universals for cats. Thanks.
Adam
amaple is offline
post #6 of 9 Old 08-18-2002, 06:08 AM Thread Starter
glennv
glennv's Avatar
Thanks, One more question though. Does the direct fit clamp right in. It looks like all I need to do is pound it out of the pipes on each end and clamp it back together. I hope so because I can't weld. Thanks for the info. Glennv
glennv is offline
post #7 of 9 Old 08-18-2002, 10:30 AM
Tomguy
2014 WK
If it's like the muffler, yes, but if it's rusted, it's a PITA. I had to take the Dremel and cut slits on my old muffler to take it off, but it was VERY easy to put on. Just be careful not to ruin existing pipes.
Hemi, Towing & Lux
198k
Previous: 1972 Benz 280SE 4.5, 1992 XJ Cherokee Laredo, 2006 Charger R/T
Tomguy is offline
post #8 of 9 Old 08-18-2002, 10:57 AM Thread Starter
glennv
glennv's Avatar
Ok one more question. I just bought the direct fit converter. The guy told me something about a tube going to the cat from the manifold. He said make sure I don't need it or I'll blow out my muffler. I took a look and didn't see anything like that.Does this sound right? Also, the length of the converter is the same as the old one but the converter itself looks a little bit smaller than the original. Is this ok? Thanks, GV
glennv is offline
post #9 of 9 Old 08-18-2002, 11:02 AM
arpy
as long as the inlet and outlet are the same size as stock it should fit and work.
arpy is offline
rear end making noise doug8949 XJ Cherokee Technical Forum 3 05-09-2009 04:11 PM
Powersteering making a noise ben_stewart XJ Cherokee Technical Forum 3 05-01-2009 09:27 PM
Axle is making noise That1guy XJ Cherokee Technical Forum 2 01-10-2009 07:45 PM
Front end making noise when in 4WD HELP!! wakeskatemike XJ Cherokee Technical Forum 17 12-30-2008 12:08 AM
my xj is making a funny noise B!G RED XJ XJ Cherokee Technical Forum 1 02-16-2006 02:28 PM
