Car dies when I let off gas - JeepForum.com
post #1 of 16 Old 10-05-2004, 03:34 PM Thread Starter
jaredlangston
My 99 cherokee sport died when I let off the gas. When I went to start it I had to give gas to even get it started. When I did start it as soon as I let off the gas it died. I checked underneath and no leaks or the smell of gas. So, I started it and gave it a little gas just enough to keep it from dying and put in real quick into drive. Drove around the parking lot just fine. When I stopped it didn't die ran fine. Pulled back into a spot turned it off and back on and it started right up. Drove it home. I'm going to let it sit for a couple hours and try to start it. Can anyone explain to me what happed and if I need to replace anything.
jaredlangston is offline
post #2 of 16 Old 10-05-2004, 04:13 PM
XJ1990
A few years back my moms '99 Grand Cherokee Limted had the same problem... Found out it was the IAC(Idle air control). Same symptoms and everything so that could be it.
1990 XJ Pioneer 4-door
*4.0L*
AW4 Auto
Dana 35/30
NP242 TC
RE 3.5" Super-Ride
31X10.5 All Terrains
www.cotrails.com/forum
XJ1990 is offline
post #3 of 16 Old 10-05-2004, 05:04 PM
stuartgray
stuartgray's Avatar
Definately sounds like a minor problem. One of the many emissions related sensors most likely. Just gotta figure out which one
stuartgray is offline
post #4 of 16 Old 10-05-2004, 09:29 PM
DefaZ
DefaZ's Avatar
My 97 did that for a while and it completely went away when I replaced the battery.
You might want to get yours checked out before taking the problem too far....
....or else might occur.
DefaZ is offline
post #5 of 16 Old 10-05-2004, 10:19 PM
Islandroaddie96
Islandroaddie96's Avatar
Yep, check your batt.
Same thing happens to me every time I had to get a jump before I replaced the batt. My theory is that since the computer feeds directly off the battery and requires a certain amount of power for it to run, it will quit if the battery is not putting out enough juice. The only way to keep it from dying, is keeping the alternator output up enough to keep the battery strong. The funny thing is that the battery has enough juice to crank the engine, but not keep the electronics going. Once you build a significant battery charge, the motor will be able to idle normally (as what happened in your case). Let it sit overnight and see what happens.
Good Luck,
Peter
1996 XJ Sport
4.0L I6 HO; AW4; NP242; D30/D35; 3" Homebrew BB; 31" x 10.5" BFG A/T
Six Harbor Freight Lights (el cheapo)
GREEN JEEP CLUB MEMBER #74
Islandroaddie96 is offline
post #6 of 16 Old 10-06-2004, 04:46 AM
boandjill
Check your throttle body control
I had the same problem last year on my 99 SE. Had a filthy throttle body. As soon as a let off the gas, it would die. Had it cleaned and runs like a champ now.
boandjill is offline
post #7 of 16 Old 10-06-2004, 08:16 AM
ISLANDSURFER
I had the same exact problem with same exact Jeep... Took it to the dealer to figure it out because I heard it could have been many things but come to find out the service people told me my battery shorted.. They explained to me that the starter only needs a very little amount of juice to start but the because the battery was bad, the computer would act up... So, check you battery..
ISLANDSURFER is offline
post #8 of 16 Old 12-10-2013, 07:30 PM
Kristina203
96 Grand Cherokee dies when i start it if i let off the gas.
Hey yall, so i have a 1996 Grand cherokee limited. And my dad and everybody is used to working on Chevys so we aren't really sure what is going on. I try and start it and in order for it to start i have to keep pressing on the gas, once i let off the gas it just dies. I know its not electrical. Does anybody know the Real solution to this problem??
Kristina203 is offline
post #9 of 16 Old 12-10-2013, 08:13 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Welcome to the forum.
All of the above are proven solutions to the problem.
Which one is right for you depends on what's causing this problem for your jeep, but at least now you've got a good idea of some basic things to check to figure out what your jeep needs.
***Chris***
chris87xj is offline
post #10 of 16 Old 12-10-2013, 09:04 PM
Paradise XJ
1988 MJ Comanche
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #11 of 16 Old 12-10-2013, 09:06 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Be nice. At least she went to the effort to search out some info relevant to her jeep's situation.
***Chris***
post #12 of 16 Old 12-10-2013, 09:31 PM
Paradise XJ
1988 MJ Comanche
OK, I'll shut up!!
post #13 of 16 Old 12-10-2013, 09:34 PM
uberxj92
1992 XJ Cherokee
This holds true for most all vehicles with ecm. The ecm requires no less than 10 volts to operate correctly. So that leads to power.
1: clean battery cables
2: load test battery
3: most batteries are only good for 2-5 years depending in usage and demographic.
4: test alternator
5: make sure everything is off when you start. A/c lights stereos etc...
6: when you buy a battery make them load test it right there before you pay. Parts stores are infamous for retagging batteries that have sat beyond shelf life. Walmart doesn't do that.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #14 of 16 Old 12-10-2013, 09:39 PM
uberxj92
1992 XJ Cherokee
Just to get this out there...
By pressing the gas pedal on an efi vehicle to start it. You're actually forcing the ecm to advance the timing. Essentially bypassing the problem that's nit allowing a normal start. This isn't a bad thing but it shouldn't be done all if the time.
uberxj92 is offline
post #15 of 16 Old 12-11-2013, 04:37 AM
green97xjsport
1997 XJ Cherokee
Your first 2 responses probably hit the nail on the head, just bought mine a few days ago with the exact same problem, had a bad battery with crappy cables and a loose connection to the battery and was throwing iac codes, replaced both, problem gone, and no more codes.
green97xjsport is offline
Mj Dies kc9afz MJ Comanche Technical Forum 2 08-28-2007 09:33 AM
Just dies.... nicksamba XJ Cherokee Technical Forum 1 03-08-2007 07:24 PM
dies when wet? 89Cherokee4x4 XJ Cherokee Technical Forum 4 11-09-2006 03:07 PM
My GC shudders then dies. What gives? alphadenim XJ Cherokee Technical Forum 2 02-17-2006 03:59 PM
MJ dies StormFX MJ Comanche Technical Forum 1 08-24-2005 06:24 PM
