Can't get out lower Ball joint - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Can't get out lower Ball joint
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 10-20-2008, 08:58 PM   #1
CharlieMopps
1989 XJ Cherokee
So, after I got the stupid knuckle off (see my other thread) I was able to get the upper ball joint out pretty easily.
The lower... well, that's another story.
I've read 3 different guides. I have the rental tool from Autozone. It's pretty beafy. I put my 650ft/lb impact wrench on it and torqed it until the wrench would not turn anymore. Then I put my socket wrench on it, put a 3 foot pipe wrench on it, was able to turn it 3 more times before I sheared off the driver on the wrench.
So! Any tips? and yes, I've searched.
One thing I haven't tried is heat. Any tips would be appretiated. I can't work on it until I get a new wrench tommorow. I'm also concerned about destroying my rented tool... lol
CharlieMopps is offline   Reply With Quote Quick reply to this message
Unread 10-20-2008, 09:45 PM   #2
tangofox007
Which way are you trying to move it? Up or down?
tangofox007 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2008, 10:21 PM   #3
CharlieMopps
1989 XJ Cherokee
down
This is an 89 and the ball joints never been changed.
Unread 10-20-2008, 10:28 PM   #4
rob92xj
1992 XJ Cherokee
Air Hammer and heat usually works for me.
rob92xj is offline   Reply With Quote Quick reply to this message
Unread 10-20-2008, 10:36 PM   #5
HeepToJeep
1982 CJ8
The lower balljoints on my 89 were a mother to get out, you absolutely can not beat on them or it winds up "mushrooming" the top edge and wont allow them to push out....if it hasn't been beat on then I would make sure:
Uhohzone gave you the correct adapter w/ the press kit.
You're using the correct adapter.
The balljoint has been soaked with penetrating lube and allowed to sit long enough to get in there.
You're putting the press on straight, if you try pushing it out at the incorrect angle it will not budge!
And for future reference, using an impact on a balljoint press can send shrapnel at your head.....the correct method to removing a balljoint is slow and easy.
Wm
HeepToJeep is offline   Reply With Quote Quick reply to this message
Unread 10-20-2008, 11:09 PM   #6
tangofox007
You might try rapping the yoke with a hammer after loading the press as much as possible. Sometimes, two hammers on opposite sides will do the trick. Penetrating oil will help, also.
Unread 10-21-2008, 03:45 AM   #7
Jeepsr4me19
1976 CJ5
Just let it set over night. I did the same thing and went in to eat supper and then it started raining. Got up the next day and it had moved.
I will try my best to only answer what you ask.
Jeepsr4me19 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2008, 01:52 PM   #8
CharlieMopps
1989 XJ Cherokee
Would it be possible to drill it out at all? It's REALLY stuck. I might pick up an air hammer at harbor freight tonight. They're only $20 right?
Unread 10-21-2008, 04:38 PM   #9
CharlieMopps
1989 XJ Cherokee
I've beaten it with a hammer.
I've bought an air hammer and beaten it until my compressor just failed
There's no way for me to get PB blaster in there... the metal looks fused together it's so old. Any other ideas?
Unread 10-21-2008, 05:20 PM   #10
tangofox007
Are you supporting the axle close to the ball joint? If not, much of the force will be absorbed by the suspension.
Unread 10-21-2008, 05:33 PM   #11
justanotherjpr
Propane torch it, beat it with a hammer. Be sure you have a jack stand under the axle tube just behind the knuckle so all the force goes to the joint. It's just metal. It will eventually do what you want it to do.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline   Reply With Quote Quick reply to this message
Unread 10-21-2008, 05:33 PM   #12
CharlieMopps
1989 XJ Cherokee
pretty close... I suppose I could get it closer.
So there's no nut/pin/ring that holds this thing on right? I can't see anything.
Unread 10-21-2008, 05:35 PM   #13
justanotherjpr
I just changed one last week. There is no magic answer, no pin, no lock ring, no tab. Try hitting the side of the knuckle instead of the head of the joint. Try flipping the press over and hitting it deeper in. Anything to try to break the corrosion. If the shaft is still in the joint. you can try hitting that, too. To avoid mushrooming the head, use two hammers.
Unread 10-21-2008, 05:57 PM   #14
tangofox007
I believe that the knuckle is already out of the picture.
That would drive the ball joint in, not out. Not to mention that getting a good swing would be impossible unless the vehicle was on a lift.
Unread 10-21-2008, 06:05 PM   #15
tangofox007
In some applications, that joint was secured with a circlip. But there should not be one on an XJ.
If I were you, I would load the joint as much as possible with the press. Then strike the sides of the axle yoke perpendicular to the joint. Use two large hammers st the same time, striking on opposite sides of the yoke. The objective is to send a deforming shock wave through the yoke that will break things loose. I have had good success with that technique, much better than beating the joint itself. Copious amounts of penetrating oil will also help. Kroil is the best if you can find some.
