Quantcast Can't choose LEDs! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Can't choose LEDs!
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 01-14-2009, 08:33 PM   #1
LordBronz
1994 XJ Cherokee
Can't choose LEDs!
http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=CAR&keywords=&cart_id=2886062 .21910&next=50
Those are the bulbs I am looking at. I have seen that the tri-LEDs are pretty bright, but don't want to spend $4 per bulb . These are the ones I'm looking to get.
T1.5-x Instrument LED bulb
1-LED Instrument Cluster and Gauge illumination bulb. #74 LED bulb installed in twist lock socket base
Select LED Color
$ 1.79
In red. I have a white speedometer stick thing. Will this shine red?
Thanks.
LordBronz is offline   Reply With Quote
Old 01-14-2009, 09:30 PM   #2
mattathayde
i would assume so, depending how your dash is though check to make sure any parts that the lights shine through are not tinted, if it is you will get a mixed color
-matt
mattathayde is offline   Reply With Quote
Old 01-14-2009, 11:10 PM   #3
ehall
1991 XJ Cherokee
You can save a little by buying the #74 bulbs alone and reusing your existing twist-lock bases
ehall is offline   Reply With Quote
Old 01-15-2009, 02:22 PM   #4
LordBronz
1994 XJ Cherokee
Yea, that is what I planned to do. I'm going to go ahead and buy the ones I looked at. Hopefully they will be bright! Should I get about 6?
Old 01-15-2009, 03:35 PM   #5
ehall
1991 XJ Cherokee
The secret to using the superbrightleds site is the MORE INFO button on the product pages. http://www.superbrightleds.com/specs/74.html has are all of the #74 bulbs they offer, their brightness, color spectrum, etc.
I bought the 74-WHP (cool white) for the switch backlights and they are kind of blueish, but it looks alright there. However it does not work for the HVAC controls which have white, red and blue text, which all gets washed into blue, and I ended up buying a natural white #74 bulb from http://www.autolumination.com/ to more closely match the gauge and cabin light color. Here's a poor pic that shows how blue they are
For the indicator/warning lights I bought a bunch of the red, amber, and green bulbs as appropriate for the indicator color, and the only problem I've had with those is that some of the indicator circuits have ambient voltage that the LED displays (low washer fluid is always partially lit up, for example). The single SMD bulbs are all plenty bright.
Old 01-15-2009, 05:58 PM   #6
LordBronz
1994 XJ Cherokee
Ahh, those don't seem very bright. Are they brighter, just the picture makes them looks very faded (gauges)?
Old 01-15-2009, 06:36 PM   #7
mattathayde
2nd that, i know there are some leds that would be fine but those do look kinda faded, but then again my Exploder dash had really dim spots with all the bulbs in place so not sure if its the dash or the lights
how to LEDs fair as dash lights with the dimming function, i know some LEDs can dim and some cannot, any one notice anything off with it?
-matt
Old 01-15-2009, 06:38 PM   #8
LordBronz
1994 XJ Cherokee
Let us hope they are dimmed. If so, I can buy them.
Old 01-15-2009, 08:30 PM   #9
ehall
1991 XJ Cherokee
1) I already said it's a bad pic
2) The gauge bulbs are not #74, nevermind the #74 in question
Old 01-15-2009, 09:37 PM   #10
LordBronz
1994 XJ Cherokee
Ok... well I think I am just gonna go with the ones I listed before.
Old 04-22-2009, 08:30 PM   #11
ChiliPepperXJ
ChiliPepperXJ's Avatar
LordBronz, Did you ever get those bulbs and install them?
ChiliPepper XJ DD build thread(Pic Extensive)
Present: 1998 Jeep Cherokee Sport
4.0L I6, NP 231, AW4
15x8 Canyon Wheels, Goodyear Wrangler GS-A 30"
RC 3" Lift
Past: 1992 Jeep Cherokee Laredo
4.0L HO I6, NP 231,AX15-5, 354,000 miles
ChiliPepperXJ is offline   Reply With Quote
Old 04-22-2009, 09:26 PM   #12
LordBronz
1994 XJ Cherokee
Yes, I did. They didn't work because they were too small for the twist sockets. I think you can order different sized ones though.
littleblackXj - You are the man!
xjfever - So are you!
Old 04-22-2009, 09:27 PM   #13
ChiliPepperXJ
Ok, I was just curious, I wanted to see some pictures : )
RC 3" Lift
Glock Forum
