Can you swap jeep cherokee computer with grand cherokee - JeepForum.com
post #1 of 15 Old 07-02-2011, 09:07 PM Thread Starter
jonnyboy99
Yeah man i'm a new member. WooHoo!
Got a Question. I have a 1998 Jeep Cherokee Limited inline 6 4.0L. I think my computer is bad but not sure. I'm getting no spark at the plugs. I've read on here about people having the "no spark" issue and have replaced the crankshaft position sensor, camshaft position sensor, and ignition coil. Still no spark. My next guess is to replace the cars computer. (also none of my gauges work.)
I want to know if i can swap out a computer from a 1998 Jeep Grand Cherokee V8 and put it in my jeep cherokee. Are they compatible?? Many thanks!
jonnyboy99 is offline
post #2 of 15 Old 07-02-2011, 09:34 PM
newfieZJ
That PCM will not work for many reasons
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 15 Old 07-02-2011, 10:57 PM
keepishop
1989 XJ Cherokee
ASD relay comes to mind, but that might be for fuel not spark.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #4 of 15 Old 07-03-2011, 12:07 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If you're hell-bent on changing the computer, go get one from the junkyard. But, why not do some testing first?
cruiser54 is offline
post #5 of 15 Old 07-03-2011, 04:57 AM
Kevin108
If the computer from a 99 will work in your 98, I can make you a deal, but I doubt it's the computer.
No gauges and no spark is typically the crank position sensor. Is yours the one hole or two hole sensor? Are you getting NO BUS on odometer?
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #6 of 15 Old 07-03-2011, 11:06 AM Thread Starter
jonnyboy99
I've already replaced the crank position sensor. It is the 2 hole type. Odometer reads fine, 168,xxx. The ASD relay is fine. I'm getting fuel to the fuel rail. Have checked all fuses. I'm not getting power to the ignition coil. (tested with voltmeter)
How do you know if the computer is bad and/or how do you test it?? thanks guys!
post #7 of 15 Old 07-03-2011, 12:40 PM
Luke94XJ
1994 XJ Cherokee
If you can find a 96-99 computer for an I-6 engine you can swap it in there. Chances are it's not the computer.
Luke94XJ is offline
post #8 of 15 Old 07-03-2011, 02:03 PM
hobo2
i check the fuse in side the jeep it a 20 or 25 amp fuse check owner manual said starter
hobo2 is offline
post #9 of 15 Old 07-03-2011, 02:07 PM Thread Starter
jonnyboy99
Ok we ended up putting the computer from the Grand Cherokee in there and now we are getting spark. So know i need a computer for my 1998 Jeep Cherokee Limited I6.
post #10 of 15 Old 07-03-2011, 02:15 PM
newfieZJ
You could get one at your local scrap yard , try posting in the wanted section , try ebay , or try contacting Kolak@AOL.com .
newfieZJ is offline
post #11 of 15 Old 07-03-2011, 03:32 PM
Luke94XJ
1994 XJ Cherokee
Scrap yard, got one for $50, but it didn't end up curing anything for the jeep I was messing with.
Luke94XJ is offline
post #12 of 15 Old 07-04-2011, 06:11 AM
Kevin108
This is kind of off the wall, but make sure your fuse box on the passenger fender is bolted down tight. Some guy was having the same issues as you and it turned out to be a poor ground at the PDC or whatever it's called.
Kevin108 is offline
post #13 of 15 Old 10-02-2014, 03:30 PM
bobbito1287
i have a 1995 jeep cherokee 4.0 6 cylinder and recently all the gauges but the battery and oil gauges stopped working along with my windshield wipers wont wipe anymore. I took it to a shop and the tested it to see what could be wrong but all they could come up with is that maybe the PCM is malfunctioning and to replace. Could it maybe be something else since all other electric works ie radio, turn signals, lights, and how could i test it myself?
bobbito1287 is offline
post #14 of 15 Old 10-03-2014, 07:39 AM
AZ Jeff
2014 JK Wrangler
Since the PCM is not involved with wiper operation in ANY way, the shop is obviously totally guessing (and incorrectly at that!!!)
I would bet your issue is either a loose or corroded connector where the wiring goes through the firewall, or a bad ground. It's certainly NOT the PCM.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #15 of 15 Old 10-04-2014, 12:42 PM
bobbito1287
PCM wiring
is there a way for me to be able to test myself or videos demonstrating how to do this to find the problem?
computer , ecu
Engine Swap Question 95 Grand Cherokee to 90 Cherokee twmart XJ Cherokee Technical Forum 3 08-04-2010 05:17 PM
axle swap grand cherokee to cherokee kpluard XJ Cherokee Technical Forum 2 03-17-2010 10:01 PM
Grand Cherokee to Cherokee engine swap? dogbluedrummer XJ Cherokee Technical Forum 5 02-22-2008 09:57 AM
96 Grand Cherokee Computer Problem Timster XJ Cherokee Technical Forum 1 11-01-2006 12:30 PM
Swap stock wheels 99 Cherokee to 96 Grand Cherokee?? JeepsJeeps XJ Cherokee Technical Forum 2 10-09-2006 04:41 PM
