Can you run without an ECU? - JeepForum.com
post #1 of 12 Old 02-19-2013, 07:38 PM Thread Starter
aldersonfilm
Is it possible to still start and drive if the ECU is damaged or missing entirely?
aldersonfilm is offline
post #2 of 12 Old 02-19-2013, 08:25 PM
mtwask01
1995 XJ Cherokee
Only if you retrofit to a carburetor. The ECU is the brain of the fuel injection system and is absolutely necessary. If it is damaged, it may still run and drive depending on the severity of the damage, but if missing entirely, it absolutely will not run.
mtwask01 is offline
post #3 of 12 Old 02-20-2013, 12:35 PM
sAe23
1995 XJ Cherokee
You'd probably have to change the distributor too, and who knows what else...
OP, why not just unplug it and see for yourself ?
sAe23 is offline
post #4 of 12 Old 02-20-2013, 01:31 PM
Pats94
Go to a carb, distributor set up. If you have a auto thats going to need to be addressed.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
post #5 of 12 Old 02-20-2013, 05:56 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Gotta know.....why are you asking?
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 12 Old 02-20-2013, 07:38 PM Thread Starter
aldersonfilm
Haha this was purely a curiosity question. I pulled the battery cable while the engine was running to check the alternator, but I then heard that this can damage the ECU. Just making sure, I didn't do that.
post #7 of 12 Old 02-20-2013, 11:57 PM
Reptile
1991 XJ Cherokee
So you ignored a warning that it could damage your ECU and still proceeded to do it??
Sure it'll run without a ECU, I don't see why not, at least on a downward slope. Say, why don't you cut off some random wires and let us know what you get away with?
Reptile is offline
post #8 of 12 Old 02-21-2013, 01:14 AM Thread Starter
aldersonfilm
Didn't hear it could damage the ECU until I had already tried pulling the cable. Seems to be running fine though.
post #9 of 12 Old 02-21-2013, 05:26 AM
Hudson
Get a multimeter and check the alternator that way.
Your battery should be at like 14.55 DC volts with a good alternator. (With engine running obviously). With engine off it should drain down to like 12.55 DC volts and not much lower.
Most auto stores will test alternators for you for free if you don't have a multimeter.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #10 of 12 Old 02-21-2013, 06:43 AM
Kettles
I dont know why the cable off would damage the ECU, unless the voltage regulator was bad and without the battery it somehow started generating excess voltage. But not knowing the specifics on how it works, I cant say either way if that would happen.
But I do know, if the alternator is functioning properly, the engine will run without a battery and it shouldn't hurt anything (not start mind you, but you probably knew that). The ECU controls everything, if its not there/not working, nothing works.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #11 of 12 Old 02-21-2013, 10:33 AM
tjwalker
tjwalker's Avatar
Below is a link to a good article that explains why you should not remove a battery cable on a running engine. I've fixed a couple of vehicles where it fried either the computer, the alternator, or both. Doesn't happen all the time, but why would you want to take the chance when the charging system can efficiently be tested with a simple meter.....
http://www.troubleshooters.com/dont_...ct_battery.htm
tjwalker is offline
post #12 of 12 Old 02-21-2013, 06:10 PM
Kettles
_=====o000o
Kettles is offline
computer , ecu , sensor , wiring
