Can you clean an O2 Sensor? - JeepForum.com
post #1 of 9 Old 09-14-2005, 01:07 AM Thread Starter
saxj
I know what an O2 sensor does, but have no idea how they work.
When an O2 sensor goes "bad" what happens to it?
How does an O2 sensor work?
Can you clean them or do they have to be replaced?
1996 Cherokee Limited 4x4
OME Springs, 30x9.5 M/Ts, 4.0 HO Auto, NP242
saxj is offline
post #2 of 9 Old 09-14-2005, 03:28 AM
tigerpaw580
1955 CJ2
O2 Sensor
The O2 sensor is very important to how your Jeep runs.It measures the oxygen in the exhaust and adjusts the pulse width of the injectors based on its signal.I have never seen one able to be cleaned. It is a easy replacement and just dont forget the anti seize lube on the threads, don't contaminate the tip any.
It is possible to test the o2 sensor with a digital voltmeter, check it it should read between 0.1 volt to 1.0 volts anything else and it is bad. You may also improve how your jeep's mileage is too by just replacing it, even if it is not bad yet.I have had good luck with the Bosch type sensor, just get the one with the correct terminal on the end not the universal. for either the 2.5 four or the 4.0 engine.
tigerpaw580 is offline
post #3 of 9 Old 09-14-2005, 07:35 AM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
just replace it, they're relatively cheap.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #4 of 9 Old 09-30-2005, 09:34 AM
maxpower_hd
O2 Sensor
Where did you buy your O2 sensor? I just got a price and it was $80 for the upstream and $128 for the down stream. That doesn't sound relatively cheap to me.
maxpower_hd is offline
post #5 of 9 Old 09-30-2005, 10:23 AM
xj-xile
xj-xile's Avatar
You can get them $60-$70 (each) on www.sparkplugs.com
I just bought them from the dealer $220.00 ($105.00 each, plus tax), thank you very much. So the $60 route is "cheap" in that sense.
Not that anyone cares, but I've been trying desperately to get a mechanic who will listen to me when I say my problem is not with the sensors, but with the wiring harness. The latest mechanic told me to buy the sensors from the dealer, because their tests told them that the Denso sensors I put on there were not communicating with the Jeep's computer. So I spend $220.00, right? And now, after installing them & resetting the computer, the bleeding CEL is back on...
...and my emissions inspection sticker expires at sundown today
So if anyone knows why the harness would be overloading (pumping too much electricity) into the O2 sensors, I'll take any suggestions. I measured the voltage coming from the harness to the sensors, & it seems too high, given what the FSM for a '94 XJ says (I don't have a '96 FSM, & note that a '94 is OBDI while '96 is OBDII).
xj-xile is offline
post #6 of 9 Old 09-30-2005, 10:24 AM
XJ99
XJ99's Avatar
2006 XK Commander
I paid $90.00 each, and that was at the dealer.. I didn't think that was too bad for OEM parts..
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is online now
post #7 of 9 Old 10-01-2005, 11:06 AM
4SEVEN3
The O2 sensor creates voltage. It uses voltage, but only for the heater is its a 4 wire sensor. If theres resistance between the sensor, like a bad pin in a connector, ect. and the ECU it can foul up readings. The best thing to do is using a oscilloscope take o2 voltage readings at the sensors plug and the ECU to see if theres any difference and trace it from there, take reading on the harness side of the connector for the o2 sensor. Maybe the computer is messed up?
4SEVEN3 is offline
post #8 of 9 Old 10-01-2005, 11:30 AM
dynamite44
the dealer kept feeding my jeep oxygen sensors, under warranty mind you, so after replacing sensor 1 upstream 3 times in a row (in i think 2 month's time), they rewired the engine bay, which solved the problem.
back to the subject stated earlier in the post:
i've heard of people cleaning oxygen sensors, in particular a couple of people when i worked the parts counter at pep boys. one redneck lookin guy tried cleaning his with gasoline, then turpentine. neither worked. the other guy that came in said he tried cleaning them with a wire brush, which also didn't help.
both customers wound up buying new oxygen sensors :-)
2000 XJ silverstone metallic.
dynamite44 is offline
post #9 of 9 Old 10-01-2005, 03:23 PM
xj-xile
xj-xile's Avatar
You know, I wondered whether an oscilloscope would be more accurate/useful in this situation than a multimeter. I don't have an oscilloscope though... I know what the sensors are "saying," but I don't know what the computer is "hearing" (or reading) from the sensors.
If anyone really wants the nitty gritty I'm dealing with this in a different thread on NAXJA: http://www.naxja.org/forum/showthread.php?t=66704 I'm currently still stumped. It's either the computer or the wiring. It's not (in my case) the sensors.
re: cleaning O2 sensors: I believe I read that it is possible, some long time ago while trying to solve my problem. However it is done, it must be a delicate process. In most cases, though, if a sensor causes the Check Engine light to come on, then the sensor is probably broken, & cleaning it will not fix it. I also don't think cleaning it improves its efficiency.
Everybody should take a lesson f/what I did. If you don't have a Check Engine Light on DON'T MESS WITH THE SENSOR! If you're worried about the cost of replacing it, then you shouldn't be messing with it. I've bought three sets of sensors now for a problem that apparently has nothing to do with the sensors themselves, but everything to do with the wiring harness or the computer.
xj-xile is offline
Check Engine Light - 02 sensor voltage too high bank 1 sensor 2 billbarr100 XJ Cherokee Technical Forum 15 05-19-2010 03:04 PM
Best way to clean gunk off engine, and clean the throttle body? willcherokeexj XJ Cherokee Technical Forum 7 05-24-2009 12:20 PM
TPS sensor, Coolant temp sensor, and 02 Sensor fail kadetklapp XJ Cherokee Technical Forum 2 09-07-2008 01:48 PM
How do you clean the O2 sensor sleddy5 XJ Cherokee Technical Forum 1 03-10-2005 01:57 PM
P0138 Oxygen sensor high voltage, bank 1 sensor 2 Back2Basics XJ Cherokee Technical Forum 3 08-03-2004 11:33 AM
