Quantcast Can you add pucks to coil spacers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Can you add pucks to coil spacers
Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at BasIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 02-08-2010, 11:20 PM   #1
srhcherokee24
i have a 4.5 in lift and iam adding 2in shackels to my rear leafs, and i was wondering if it would be ok if i would add would add on puck to the coil spacers? I have read on this sight that a few people have done that so that the front end does not sag. TIPS PLEASE
srhcherokee24 is offline   Reply With Quote
Old 02-09-2010, 01:45 PM   #2
LandersmiXJ
1991 XJ Cherokee
Sorry no real tips, but you can add them as long as you have shocks that are long enough and you have the correct track bar, pitman arm and so forth.
LandersmiXJ is offline   Reply With Quote
Old 02-09-2010, 02:15 PM   #3
keepishop
keepishop's Avatar
1989 XJ Cherokee
The pucks are for extending your bumpstops, not more lift.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline   Reply With Quote
Old 02-09-2010, 02:55 PM   #4
UltimatE
Resident Audio Guru
UltimatE's Avatar
Agreed. Pucks are used to extend your bumpstops. If you want to level out the ride height, look for coil spacers and/or leveling kits depending on just how much you need to level it.
Also be aware that adding large lift shackles to the rear will change your driveshaft angle and could induce vibes.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Old 02-09-2010, 03:08 PM   #5
LandersmiXJ
1991 XJ Cherokee
Sorry i was thinking he was refering to coil spacers as pucks, cause i often do. But yes hockey pucks can be used as bumpstops. thanks for the correction.
Glock Forum
