Can someone aware me on this "lift" (PIC) - JeepForum.com
post #1 of 6 Old 09-26-2013, 05:44 PM Thread Starter
bostondparty
Junior Member
Just bought my first XJ, this one is sitting at 2" above stock. This is what is in the rear, PO said it is all the way down and can get 2 more inches if adjusted.
Most likely changing out for a RE 3.5 kit soon, but how does this work?
bostondparty is offline
post #2 of 6 Old 09-26-2013, 05:56 PM
mschi772
1997 XJ Cherokee
Looks like an adjustable shackle attached to seriously sagging (looks inverted) leaf spring. It looks as if the shackle is adjusted by turning the end in and out (it's threaded together like any other adjustable suspension piece such as control arm or track bar). RE kit sounds like a great idea compared to this in my opinion.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #3 of 6 Old 09-26-2013, 07:22 PM Thread Starter
bostondparty
Junior Member
So what will I need to do to get back to stock? I assume full leafs with these shackles will be ridiculously tall when I only want 3-3.5"
post #4 of 6 Old 09-26-2013, 07:33 PM
Paradise XJ
1988 MJ Comanche
Just get some stock shackles which are cheap...then it will be stock...and then get your 3-3.5 leaf pack bolted to them and it will be 3-3.5" taller than stock.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #5 of 6 Old 09-27-2013, 07:22 AM
cbenez1
Is it me or does that look like someone just shortened an adjustable control arm ? I wanna bash it but it doesn't looks like that bad of an idea. As long as you don't extend it to a ridiculous length. And get a better leaf spring.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #6 of 6 Old 09-27-2013, 01:54 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
It does look pretty sturdy. I kind of like it.
***Chris***
chris87xj is offline
