Can i use an APN header on a 99 XJ?? - JeepForum.com
post #1 of 4 Old 02-14-2011, 11:55 AM Thread Starter
JoshsXJ31
okay so yeah my header is cracked on my 99 xj. seems like its pretty common. and after reading reviews and stuff it seems that the APN header is the way to go, but on thier website is says that its only for a 91 thru 98 cherokee. and not to order if your year make and model is not on the list, because ""It will NOT fit “other” 4.0L Jeep applications."" their exact words. but since people are putting these headers on with 99+ intakes why cant i just put it on my 99? so has any one put a ANP headder on a 99 xj and had it work out? and what if anything did you have to do?
JoshsXJ31 is offline
post #2 of 4 Old 02-14-2011, 12:16 PM
muttyranks
it fits...just need to take a grinder to the #6 runner on the new exhaust manifold....it has clearance issues with the 99 intake mani.
muttyranks is offline
post #3 of 4 Old 02-14-2011, 12:24 PM
trevsbmw
I have an APN on my 99 but forgot about grinding the "runner" off. After a little extra torque to the bolts the "runner" popped of and the exhaust mounted flush and sounds good after 5000 miles.
1999 2 Door Cherokee SE w/ 4.0L I-6. Automatic. APN Header, Hooker Aero Chamber Muffler. Hella H4 Euro Headlights w/ Hella Xenon Bulbs, Eautoworks.com wiring harness, Heated Seats
trevsbmw is offline
post #4 of 4 Old 02-14-2011, 12:25 PM
alexrule123
alexrule123's Avatar
It will works as stated above but I had to not only grind the #6 runner but also #1 runner. Otherwise upon start up there was such a vacuum leak the engine would redline almost instantly.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
89 XJ header Rob104254 XJ Cherokee Technical Forum 0 09-21-2010 06:43 PM
APN Header or Pacesetter Header? Help ASAP Element96x XJ Cherokee Technical Forum 8 08-05-2009 02:44 PM
Apn Header miketyson XJ Cherokee Technical Forum 4 03-02-2007 05:50 PM
header xjinthemud XJ Cherokee Technical Forum 7 11-25-2003 02:34 PM
