can i replace the rods and bearing from the bottom ? - JeepForum.com
post #1 of 22 Old 08-30-2010, 11:39 AM Thread Starter
migsk8
ok so today as i was leaving the back i was accelerating like a grandma like usual, the jeep started shaking for a split second from the motor, i saw ton of black smoke come out from the rear view mirror, so i shut it off and guided into a parking spot. i look under the jeep and oil is pouring everywhere. this is what i find.
so my question to you guys is, if i threw a rod, can i replace the bearing and broken rod from the bottom of the jeep without even taking out the motor ?
what would be the easiest way to go about this ? i dont know exactly what happened yet but that is my guess, it blew up about 30 minutes ago and im about to tow it home in a little bit.
migsk8 is offline
post #2 of 22 Old 08-30-2010, 11:44 AM
Tony89
I'm going to guess if you threw a rod like that, the chances of the block and crank still being ok, are probably about as good as my chances of the cherokee taking flight on the way home today.
To answer your question, no. The motor will have to be pulled and disassembled to check the block, crank, and possibly head.
98 XJ - 4.5" Lift, 32" BFGs, Lots other stuff
Tony89 is offline
post #3 of 22 Old 08-30-2010, 11:46 AM
robsjeepxj
You can do all the work with the motor in the jeep if that's how you want to do it , it will be a lot harder to work on that way though, but I don't think you can get the pistons and rods out from the bottom you'll need to pull the head. You can replace the bearings on the big end of the rods and the crank bearings from the bottom but that probably won't help you much I don't think.
robsjeepxj is offline
post #4 of 22 Old 08-30-2010, 11:48 AM
Saudade
1988 XJ Cherokee
The easiest way would be to find a JY motor of a compatible year and swap it out.
While "technically" you could change the rod out, you have to drop the tranny so you can lower the crack to remove the piston (assuming it's not laying in the pan). IMO, it would entain so much work that pulling the motor would be easier.
Saudade is offline
post #5 of 22 Old 08-30-2010, 11:52 AM
robsjeepxj
I remember having to hone down the ridge on the top of the cylinder to get the pistons out the top, I would think it would be impossible to get it out from the bottom. Have you done this? And gotten the new piston in with all the new rings intact?
post #6 of 22 Old 08-30-2010, 12:54 PM
fishermanfloyd
1997 XJ Cherokee
That engine is junk without machine work.
Originally Posted by afbond03 View Post
I am trimmed and hope to get a pair one day.
fishermanfloyd is offline
post #7 of 22 Old 08-30-2010, 01:09 PM
AZ Jeff
2014 JK Wrangler
1. you MAY be able to REMOVE the piston from the bottom, but you sure WILL NOT get it back IN from the bottom
2. the crankshaft is almost certainly screwed up on journal for the broken rod. You will not be able to sucessfully replace that bearing and have it last without having the journal ground for trueness.
For the above reasons, your engine cannot be repaired without the services of a machine shop and pulling the head.
One question for you, out of curiousity------
Aside from the shaking you reported, wasn't the engine making a ton of BAD NOISES before it failed? Rods RARELY break without giving warning sounds unless you are revving the engine to or past redline when they let loose.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #8 of 22 Old 08-30-2010, 01:22 PM
lowicz96
1995 XJ Cherokee
Take the oil pan and head off to see the damage. A buddy and i replaced a broken rod in a hydrolocked heap and hes been driving for awhile. We just took a piston and rod from a spare motor and put it in a stock height YJ, it smoke a little but is probably the valve stem seals. The jeep didnt come with the oil pan but i think it was trashed too. Just be careful with the bearing sizes, piston size/rings and use assembly lube.
Or excuse for a stroker
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #9 of 22 Old 08-30-2010, 02:27 PM
rmack
no, the engine needs to be pulled, inspected and cleaned to get the schrapnal out before you ever replace anything.
rmack is offline
post #10 of 22 Old 08-30-2010, 03:15 PM Thread Starter
migsk8
there was no noise pointing out rod knock, i was at about 1,800 rpms when it went. it was just a sudden split second shake then a boom. thats it.
migsk8 is offline
post #11 of 22 Old 08-30-2010, 03:17 PM Thread Starter
migsk8
well crap, so pretty much buy a used motor and put it in.FML im so broke right now, anybody know where i can get a pretty good price on a used 4.0 for my 99 ?
migsk8 is offline
post #12 of 22 Old 08-30-2010, 04:55 PM
menace2
Sometimes a cap or cap screw will just let go like that. I had a 4-banger do it, no warning.
The head does have to come off to replace the rod/piston. It can be done with the block in the Jeep though.
Just get a used motor. They are cheap and everywhere. The junkyards are full of 4.0 Jeeps these days. Insurance companies total older ones when body work is close to bluebook.
menace2 is offline
post #13 of 22 Old 08-30-2010, 05:00 PM Thread Starter
migsk8
will any 4.0 fit in it with all the accessories ? i still wanna keep my cruise control and all that =)
migsk8 is offline
post #14 of 22 Old 08-30-2010, 05:09 PM
menace2
Almost. There are a couple of threads going on this, one guy just finished.
You don't say anywhere what year you have.
menace2 is offline
post #15 of 22 Old 08-30-2010, 05:50 PM Thread Starter
migsk8
its a 99, what motors are compatible with my accesories ? im guessing like 97-00. i dont want a 01 for obvious reasons i dont want to happen again
migsk8 is offline
How to replace front output bearing on a NP231 transfer case? oldford XJ Cherokee Technical Forum 6 07-01-2011 06:55 AM
Replace the Steering Stabilizer When doing Tie-Rods? gtospeeding XJ Cherokee Technical Forum 7 08-20-2009 09:38 AM
Rear whell bearing replace on D35 Catalina XJ Cherokee Technical Forum 3 11-05-2006 07:28 PM
Wheel bearing going out, how tough to replace? LXguy XJ Cherokee Technical Forum 6 08-20-2006 11:29 PM
Replace Wheel Hub and Bearing 360 bucks!! Renegade_Rick XJ Cherokee Technical Forum 4 02-20-2006 08:31 PM
