Can i add another lift kit - JeepForum.com
post #1 of 4 Old 03-16-2011, 04:52 PM Thread Starter
markew36
1995 XJ Cherokee
i have a 95 cherokee with a 3 inch suspension lift and i wanted to add more. I am looking for about 2 more inches of lift and would like it to be fairly cheap. thanks
markew36 is offline
post #2 of 4 Old 03-16-2011, 07:06 PM
Cavitation
You need to do lots of homework. Read read and read some more.
Cavitation is offline
post #3 of 4 Old 03-16-2011, 07:24 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
There are lots that need upgrading to go to 5" of lift. 3" doesn't require that much, but to go to 5" you will need adjustable trac-bar, adjustable control arms at a minimum long-arms would be a lot better, longer shocks, longer brakelines, longer swaybar endlinks or disconnects, a Slip yoke eliminator and new rear cv style driveshaft, shims for the rear axle. It won't be cheap if you want to be happy with it.
xjfever is offline
post #4 of 4 Old 03-16-2011, 07:29 PM
J-Stormz
2014 JK Wrangler
^^^^ what he said
J-Stormz is offline
cherokee , lift
2" Lift, no rear sway bar...should i be nervous on a jack lift Topgun514 XJ Cherokee Technical Forum 4 04-18-2011 12:46 PM
Just got a sweet 1 owner 92 xj laredo 123k should I lift it if so which lift 3" SomerJeep XJ Cherokee Technical Forum 9 07-08-2010 08:08 AM
3" Pro Comp lift and Daystar econo lift THEANGRYAX XJ/MJ Cherokee Non-Technical Forum 1 02-05-2010 06:47 PM
Is my informal list of lift parts complete? (3.5-4" of lift not from a kit) GeologistFelix XJ Cherokee Technical Forum 1 12-28-2009 09:10 PM
Any difference between lift brands? AKA: whats the best lift brand? boodis XJ Cherokee Technical Forum 15 01-03-2009 09:26 PM
