Can exhaust manifold leak damage anything? - JeepForum.com
post #1 of 9 Old 12-19-2005, 09:10 AM Thread Starter
saxj
Question Can exhaust manifold leak damage anything?
Hi all,
Someone told me that my leaking exhaust manifold could cause burnt valves.
Is this true?
Can anything else be affected?
1996 Cherokee Limited 4x4
OME Springs, 30x9.5 M/Ts, 4.0 HO Auto, NP242
saxj is offline
post #2 of 9 Old 12-19-2005, 10:43 AM
gumcrew2
1991 XJ Cherokee
Burnt valves? I highly doubt it. The only real thing it can do is make your engine run hotter (hot gasses in the engine compartment) and possibly cause premature wear on your air filter. Other than that it'll just smell funny sometimes. If it does, just open the window to get some circulation. DO NOT turn on the heat or A/C if it starts smelling weird, it'll make it worse.
"Nitrous? So is that like viagra for your Jeep?" -mom
"I flopped it"
gumcrew2 is offline
post #3 of 9 Old 12-19-2005, 10:46 AM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Well if it gets sucked into the cab it could possibly kill you without fresh air, and it makes your xj sound like a tank on a cold morning.
Other than that, its just an annoyance.
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline
post #4 of 9 Old 12-19-2005, 11:17 AM
Koenig
Koenig's Avatar
I think if you run an exhaust manifold leak for too long, you run the risk of warping the mating surfaces enough that if you do change it out someday, you will need to get the surface machined flat again.
How easily this will happen, i'm not really sure. I'm sure there is someone on this board with more experience than me on the subject!
1989 Jeep Cherokee Laredo "Betsy"
~147,000km, 4.0l, AW4, K&N custom cone intake,
Dark Cordovan Pearl Metallic in color, 4 Dr. w/ chrome trim.
Koenig is offline
post #5 of 9 Old 12-19-2005, 01:11 PM
Tweaker_G
This is somewhat off topic, but I used to have an old dodge daytona and the turbo somehow rattled loose. Anyways it was blowing all that hot exhaust onto the little heat shield there. On top of that I had a leaky fuel injector that was soaking that fiberglass heat shield. I had a great time trying to use the squeegy at the gas station to get the fire out when it finally decided to burn.
Tweaker_G is offline
post #6 of 9 Old 12-20-2005, 12:26 AM Thread Starter
saxj
Besides the noise and noxious fumes, anything else?
Can the O2 sensor be affected, i.e. wrong reading?
saxj is offline
post #7 of 9 Old 12-20-2005, 07:13 AM
Chip S.
Yes, indeed it can. The O2 sensor will read way lean, and your ecm will cause the engine to run very rich.
Chip S. is offline
post #8 of 9 Old 12-20-2005, 08:00 AM Thread Starter
saxj
I would assume this would affect fuel consumption and performance.
How much is this costing me in fuel?
saxj is offline
post #9 of 9 Old 12-20-2005, 10:53 AM
Chip S.
Well, figure a well tuned 4.0 gets 17-18 mpg average. Take your mileage and do the math next time you fill up. Don't forget to correct for the tire size.
Chip S. is offline
Is there any damage a cracked exhaust manifold can cause? Jeepokee XJ Cherokee Technical Forum 49 12-31-2012 03:13 PM
4.0 L Exhaust manifold gasket leak causing poor mileage? stjeepthegreat XJ Cherokee Technical Forum 4 09-13-2008 12:44 AM
EGR Valve sticking or Intake/Exhaust Manifold Leak? se7vn XJ Cherokee Technical Forum 6 10-08-2007 02:56 PM
exhaust manifold leak Exhale XJ Cherokee Technical Forum 4 08-15-2006 10:49 PM
exhaust manifold leak RedJeepOwner XJ Cherokee Technical Forum 1 07-20-2005 07:04 PM
