Can a digital TC change to a cable? - JeepForum.com
post #1 of 5 Old 04-12-2009, 05:50 PM Thread Starter
rytomi
I have an 89 Cherokee 4.0L and I need a new transfer case. I was looking at posibilities, but I ran into a snag...
Cherokees 1984 through 1991 used a speedo cable and 1992 through 2001 used a digital sensor.
Is it possible to get a 1992 or newer TC to work with a cable speedo?
Looking to buy MJ, 2.5L, 5 speed, 4x4. *PM me*
rytomi is offline
post #2 of 5 Old 04-12-2009, 09:09 PM
nhpso224
I have a '99 and it was just the standard speedo cable.
'99 XJ Classic, RE 5.5", 15x8 Baja Champs , 33x10.5 BFG MT's,. Bosh fogs, Yakima rack and alot of other stuff
'06 XK Commander, 4.7l, Crystal Inferno Red Pearl, Dark Gray 5 spokes, Slate Gray Leather intreior, Command view skylights
nhpso224 is offline
post #3 of 5 Old 04-12-2009, 09:20 PM
440_Magnum
I think the counter for the digital speedometer just bolts into the same old socket that an old-style Chrysler speedometer cable pinion goes in. I think you should be able to transfer your pinion from the old TC to the new one.
440_Magnum is offline
post #4 of 5 Old 04-13-2009, 08:23 AM Thread Starter
rytomi
So the gearing on the digital sensor is the same as the pinion gear and I can just swap them out?
rytomi is offline
post #5 of 5 Old 04-13-2009, 09:38 AM
440_Magnum
I'm pretty sure the whole pinion adaptor will swap over. Compare them at a junkyard to be sure.
Digital Clock 90Laredo XJ Cherokee Technical Forum 7 06-23-2012 09:56 PM
XJ Digital Art blue92cherokee XJ/MJ Cherokee Non-Technical Forum 10 12-31-2009 09:14 AM
Help with speedo cable change dover21 XJ Cherokee Technical Forum 2 07-29-2009 12:36 PM
Speedometer cable change nightmare notspock XJ Cherokee Technical Forum 0 04-06-2006 06:12 PM
Shorty/ Dakota Digital ? Anyone else got it? batilzown XJ Cherokee Technical Forum 2 08-06-2004 06:53 PM
