Can Check Gauges Light be caused by weak battery? - JeepForum.com
post #1 of 4 Old 04-22-2007, 06:40 PM Thread Starter
kchilaka
I was cleaning out the interior of my 1997 XJ today and because the front doors were open for a few hours (probably like 4 hours), the interior lights stayed on. I thought the battery could handle it but when I tried to start the jeep, the engine turned over real lazily and refused to catch. The starter also made a wierd chattering noise. I figured that this was because of the lights draining the battery but I also noticed that my "check gauges" light went on ! Is this normal? Can the check gauges light go on when the battery is low?
This light is troubling.. Now I am being paranoid that I shorted out something because I did clean the interior of the doors and windows with a soapy wet cloth.. I am worried now that the water went into some door switch or window switch and is creating a short somewhere..
Anyone see this "check gauges" light for a weak battery?
kchilaka is offline
post #2 of 4 Old 04-22-2007, 07:01 PM
TND3
you charged up the battery, its running fine? ... your still getting check gauges?
1999 XJ 5.5" lift 35" BFG MT
TND3 is offline
post #3 of 4 Old 04-22-2007, 07:10 PM
severous01
severous01's Avatar
if you have the key in run but not started it will stay on until you either turn it off or start the vehicle
or, if you're battery gauge is in the red or the temp is in the red...or anything else is in the red, it will throw a check gauges light...
so, charge the bat or jump it...and it should go away
severous01 is offline
post #4 of 4 Old 04-22-2007, 10:16 PM Thread Starter
kchilaka
Charged the battery and drove around.. The "check gauges" light dissapeared.. whew !.. thanks for your replies..
kchilaka is offline
Check gauges light dert XJ Cherokee Technical Forum 5 10-12-2009 06:44 AM
Check engine light caused by..bank 1 O2 sensor thats 2 month old Jeep_Runner_83 XJ Cherokee Technical Forum 2 11-12-2008 07:16 PM
Check Gauges and check battery light - 97 Jeep Grand Cheerokee Laredo darkstarpa XJ Cherokee Technical Forum 2 09-17-2006 07:24 PM
Airbag Light, Check Engine light, Gauges go dead.... OhioSpyderman XJ Cherokee Technical Forum 11 09-14-2005 10:50 AM
check gauges light? driverdriver XJ Cherokee Technical Forum 8 07-27-2004 03:55 PM
