Calling all death wobble guru's, gods, or any help really... - JeepForum.com
post #1 of 9 Old 09-19-2017, 05:16 PM Thread Starter
brandonc0320
Okay so here is the whole story. Just 2 days ago, I installed the ruffstuff crossover steering kit, which improved the feel of the wheel with the 4 inch lift. Had it aligned today, so I checked that off the list. Now, the jeep would wobble with the stock setup if I took a right hand bend at 40-45 mph, Anything above or below that it would do just fine. Now with the new kit and alignment it does the same thing, but now it's just more violent and quicker to wobble.
I checked the track bar hole after I got home from the alignment, it was egged out, so I drilled a new hole, and put a new nut, bolt, and lock washer on it to no improvement.
My tires are balanced, and there is no low spots or abnormalities in wear on any of them.
Could it be the stock LCA's causing the wobble, or could it be something bigger than that? Any help would be greatly appreciated. I'm on the verge of sending it to the junker if I keep throwing possible parts at the front end.
brandonc0320 is offline
post #2 of 9 Old 09-19-2017, 07:17 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Entire list of everything that can cause death wobble:
- Loose, worn, or incorrectly torqued suspension nuts/bolts
- Front alignment out of spec
- Loose track bar
- Worn track bar bushing axle end
- Worn track bar end frame end
- Worn track bar bolt hole on axle
- Needing an adjustable track bar
- Bad bushings/joints in control arms
- Damaged control arms or control arm mounts
- Worn/damaged shocks
- Worn/damaged tie rod ends
- Bad U Joint
- Bad ball joint
- Loose track bar frame mount hardware
- Worn/damaged track bar frame mount
- Steering box loose bolts/cracked frame mount area
- Bad front hub assembly
- Bent axle housing
CJ7-Tim is offline
post #3 of 9 Old 09-19-2017, 07:24 PM Thread Starter
brandonc0320
- Loose track bar
- Bad U Joint
- Bad ball joint
- Driveshaft(s) not balanced
- Bent axle housing
I have checked everything under the front. The track bar is adjustable. But at the alignment shop, the put the toe at 0, and someone had brought up that maybe it needs to be turned toe in just a bit.
But I also see what you mean about control arm bushings
post #4 of 9 Old 09-19-2017, 09:08 PM Thread Starter
brandonc0320
I just see absolutely no abnormal movement from any of the bushings. Could having a 0 toe setting cause this?
post #5 of 9 Old 09-19-2017, 10:07 PM
fennix12
Junior Member
fennix12's Avatar
I was finally able to find mine by having someone sit in the car and cycle the steering slightly back and forth. After getting under the car I put my hand on the pitman arm and felt for looseness or any popping, while the steering was still cycling i just followed the drag link down through the tie rods and eventually checking the track bar. Any loose tie rod end our worn out bearing can cause it, for me the top of the trackbar was slightly loose. For checking the ball joints you can lift the car up till the tires are off the ground, put a shovel underneath and use that to lever the tire up and down, look for play or any popping. Wish you the best on fixing the death wobble, it frustrated me for quite some time.
fennix12 is offline
post #6 of 9 Old 09-19-2017, 10:17 PM Thread Starter
brandonc0320
Thanks man. I just did that today. I checked all the bushings and like I said, I just installed the ruffstuff crossover steering kit yesterday and then Had the alignment done today. It's driving me insane. That's why I'm wondering if having it at 0 toe setting could be the issue
Sent from my E6810 using Tapatalk
post #7 of 9 Old 09-19-2017, 10:41 PM
fennix12
Junior Member
fennix12's Avatar
fennix12 is offline
post #8 of 9 Old 09-19-2017, 10:51 PM Thread Starter
brandonc0320
Great article. Thanks for the tip man.
post #9 of 9 Old 09-20-2017, 04:48 AM
CJ7-Tim
CJ7-Tim's Avatar
Death Wobble is almost always cause by worn, loose, or damaged steering and/or suspension parts. Usually it not caused by one single part/problem on the list above, often there is combination of weak and worn components that need replacement. Bushings are high on the list, and a simple visual inspection or wiggle by hand may not detect a worn bushing. Most XJ Cherokees are at the age and mileage that numerous steering and suspension parts should be replaced.
Cherokees should have toe-in, and lifted Cherokees with bigger tires should have a bit of extra toe-in.
CJ7-Tim is offline
