Call me stupid, tell me I didn't search the threads-too bad I did. AAl vs RLS - JeepForum.com
post #1 of 24 Old 11-29-2008, 09:47 PM Thread Starter
HornedFrogHooah
I'm still fairly new to all this and I still have those dumb questions every once in awhile.
why does everybody say get the rear leaf spring instead of the add a leaf?
See, I'm looking at RE's 3.5" SuperFlex and I'm stuck. Most people say "If you have the money, get the RLS. You'll regret getting an AAL." I can afford it, but just barely and don't really want to spend all that cash. I probably take my XJ offroad once in a blue moon, but I know if I had a kit and get the BFG All Terrains like I want... I'd be out every waking minute getting dirty.
So, once again, What is the big deal about RLS and why should I avoid AAL?
HornedFrogHooah is offline
post #2 of 24 Old 11-29-2008, 09:52 PM
bigbike
1995 XJ Cherokee
Full leaf packs will ride much better than an AAL because AAl are very stiff. An AAL also has a tendency to sag a lot quicker than a full leaf pack because like I said before it is one very stiff leaf in a typical saggy original leaf pack. The full packs are going to be better if you tow a trailer or put a lot of stuff in your XJ.
bigbike is offline
post #3 of 24 Old 11-29-2008, 09:54 PM
bikedude189
1993 XJ Cherokee
generally; they cause poor ride because they are a higher spring rate than stock. they cause premature spring failure. they cause axle wrap. that's all i got but its enough to stay away from them. if you must, go full length and try to match the spring rates, and only use on a good spring pack.
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline
post #4 of 24 Old 11-29-2008, 09:55 PM
T baggin98
1991 XJ Cherokee
Like said above... They tend to sag, I put a 4.5 RC lift with AAL's and they sagged out nearly to stock in about a year or less.
T baggin98 is offline
post #5 of 24 Old 11-29-2008, 10:08 PM Thread Starter
HornedFrogHooah
Hmm - dang. I was hoping by some miracle yall would say something like "I don't know what those crazy people are talking about, AALs are just fine!" but nooooooo.
Alright, I guess I'm splurging this Christmas.
post #6 of 24 Old 11-29-2008, 10:15 PM Thread Starter
HornedFrogHooah
See, with this next follow up question, you're definitely going to know I'm new to all this. I probably could look this one up, but if y'all are cruising this thread, hopefully you wont mind answering.
I know once you hit 4" or so you have to start getting all the extras so you can drive normal, but the RE 3.5" SuperFlex Kit should come with everything I need right? Don't need to drop my transfer case, get an SYE, or any of that other jargon that guy at 4 Wheel Parts was throwing out at me.
Sorry for being clueless - I just wanna be coooooool.
post #7 of 24 Old 11-29-2008, 11:12 PM
HighDesertXJ
1989 XJ Cherokee
regarding the SYE; Some will say yup got to have one, others will say maybe not and I will say I don’t need one and I’m running a 4.5 SF.
Depends on how you set things up I would say install your lift then decide
1989 XJ Limited, Was a freebee from orignal owner.
4.0L EFI Auto NP242 - Dana 35
Mods so far:
RE 4.5 SuperFlex - ACOS (adj coil spacers) - 15x8 - 33x10.50 AT - Dynomax Exhaust - custom frt bumper w/frame stiffners - custom base plate for towing
HighDesertXJ is offline
post #8 of 24 Old 11-30-2008, 07:04 AM
bdb12586
2005 WK
In my case anyway I did the same lift, I had to lower my tc 1.25" to clear up my ds binding. I probably should get an sye but I've been running it for a couple yrs. like that now with no real problem. As for the trac bar the kit will tell you to drill a new hole in the bracket but my experience was the bracket wasn't long enough to drill a new hole and have my axle centered. I just customized the bracket to make it work till I got the adj. trac bar, well it worked so well I didn't ever get a new trac bar still running it that way to but you should plan on buying a new one. Last thing to consider is longer brake lines for the front they tell you to relocate the hard line but you can brake the hard line and it's not as good anyway. I also wish I installed bar pin eliminators
bdb12586 is offline
post #9 of 24 Old 11-30-2008, 07:19 AM
lcarney91
With a 2001 model, you WILL have to address the driveshaft in one way or another. Either TC drop or SYE, with the SYE being a more "permanent" fix, but more money also. 97+ models are more prone to driveline vibes than the older ones, for whatever reason.
To put a little perspective in, I put overload springs on the rear of my '99, gave me about 3/4" of lift over stock, and had moderate driveline vibes about 35-42 mph.
I don't plan on anything over 2" without a SYE on mine. Yours may be different. They are all different, but you may as well plan on spending some coin and fix yours. Especially with that RE 3.5" kit, with full packs, you'll be gaining closer to 5", unless you're heavily armored/bumpered/loaded.
Good luck and let us know how it goes.
1999 XJ.....
Stock, with some intake/exhaust work
"The ol' family truckster"
lcarney91 is offline
post #10 of 24 Old 11-30-2008, 09:27 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I am going to take the other side of this discussion.
I wonder if some Web Wheelers simply repeat what they read someplace on some 4x4 forum, and have no actual experience with the AAL.
A severely sagged stock leaf spring will in fact, be harder on any AAL than a stock leaf spring pack in decent condition. That is simple physics and plain common sense. Success with any AAL lift can, and will, depend on the condition of your original leaf pack and with the AAL type used (short overload leaf type vs. a long full length leaf), and brand name of the AAL. A Short Leaf/Overload type AAL has to be very stiff to lift the rest of the saggy stock leaves. I think the first Cherokee AAL kits were the short thick overload leaf types, and this may be where the harsh riding, quickly sagging, Internet stories started. A Short Leaf/Overload type AAL also concentrates its lift effect near the spring eyes of the original stock main leaf which are already under stress and prone to sagging even on stock XJ's with little to no off-road usage. Stock leaf spring sag usually begins at the ends of the main leaf, near the spring eyes, and progresses to the smaller leaves, flattening them out. XJ Cherokee factory original leaf springs are well known to be prone to sagging even with 100% street use. A Full Length AAL spans between both spring eyes and reduces the weight load and stress that each leaf below it has to carry. The spring rate or stiffness of a full length AAL will be less than a short style AAL. It will ride a little more firmly than stock leaf springs, but shouldn't be objectionable with good quality shocks. A full length AAL can be installed into moderately a saggy stock leaf spring pack to restore normal ride height, or to add some lift.
I have installed/owned or helped my Jeep Club buddies repair or install numerous lift kits and combinations of lift. My local Jeep club has 20+ lifted Cherokees and I have owned and built 4 lifted Cherokees and a lifted CJ-7. My XJ started with extended shackles on factory stock leaf packs and so did another one of the local XJ's. A week long 4x4 trip proved that the extended shackles will sag and ruin the stock leaf springs very quickly. With a replacement lift kit spring that is designed to handle the extra flexing and load carrying of an off road 4x4 trip, extended shackles are just fine, and actually help smooth the ride and increase the flex. One of the local XJ's had 2" lift blocks and not only did the stock leaf spring sag, it went S shaped from axle wrap and then it cracked the main leaf into two pieces. We just built a bastard pack for another Cherokee using an S-10 spring pack and the original stock Cherokee main leaf. This set up works well on the road and trails and gives a little over 4 inches of lift. It gives a smooth ride and reasonable flex on the 4x4 trails. You can vary the lift height achieved by using fewer S-10 leaves or by mixing and matching S-10 and XJ leaves. Another XJ with a 3" AAL on the stock leaf pack plus an extra stock Cherokee leaf flexes and rides very well, and has not sagged at all.
I ran a Bastard Pack built with a Full Length 2.5" Add-A-Leaf from Rubicon Express on some un-sagged stock XJ leaf packs along with an extra stock XJ leaf on my 2000 Cherokee. This netted me a little over 3 inches of lift. I ran this lift on two different week long trips to Moab, and a week in the central Colorado Mountains, and regularly hauled 300+ lbs of cargo. It did well on the trails and never sagged in the least in the 3 + years this set up was on my 2000 Cherokee. Recently I installed these same lift parts on my 99 Cherokee with the original 240,000 miles of use stock leaf springs, and they still work great. They are maybe 10-15% firmer than stock, but they smooth on the roads. My current RE 3.5" lift kit Replacement Leaf Spring packs are smoother and flex better than the AAL, but they also cost more than the $100 total cost I spent buying and installing the RE 2.5" AAL.
See this thread on another XJ Cherokee forum for some bastard pack recipes -> www.naxja.org/forum/showthread.php?t=1073516
Ride stiffness is more dependent on your choice of shock absorbers and the brand name of lift parts you install, than on the actual type of lift parts, AAL vs a brand new lift kit spring pack. The cheaper brands of lift parts have a tendency to be more stiff riding. All lifted vehicles will ride differently than stock and you should expect some compromises and/or changes in ride quality when driving a lifted Cherokee.
Lift blocks contribute to axle wrap and are the least desirable lift option. Lift blocks are also the most likely lift option to cause excessive leaf spring sagging due to the addition of axle wrap to the lift equation. An AAL does not contribute to axle wrap and will actually help prevent axle wrap and leaf spring bending.
The brand name of the lift kit parts you choose for your lift will have an effect on its lifespan of the parts, and on the quality/stiffness of the ride, both on or off road. The only way to make lift kit parts cheaper is to reduce the quality of the materials used to make those parts.
Over flexing any leaf spring or over compressing any coil spring will cut its lifespan dramatically, no matter what type of lift you install. Springs simply cannot deal with the stress of over-flexing/compressing due to inadequate bump stops. So take note, no matter what type of lift you use, you are still required to extend your bump stops and you may need to buy additional parts not provided in any lift kit you purchase.
Your lift decision should be based more on your budget, and performance goals, than on any Internet mythology. If your leaf springs are in good condition, an AAL or a bastard pack is a reasonable and low cost choice to add lift, and the results will meet the needs of most 4x4 owners.
CJ7-Tim is offline
post #11 of 24 Old 11-30-2008, 09:41 AM
XJ96PA
XJ96PA is offline
post #12 of 24 Old 11-30-2008, 09:44 AM
EricsXJ
The Post man
EricsXJ's Avatar
Thanks CJ7-Tim for that well written answer.
The advice given is 100% dead on.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #13 of 24 Old 11-30-2008, 10:00 AM
XJLI
XJLI's Avatar
1993 XJ Cherokee
I'll x3 that, and follow up with the fact that I added a stock top leaf of an old XJ pack onto my stepdad's XJ and it lifted it 1.5" over stock, and he drives it all day for work, and frequently carries a few hundred pounds of tools in it. and it has yet to sag.
Factory Four Link
XJLI is offline
post #14 of 24 Old 11-30-2008, 10:03 AM
91xjgawes
Originally Posted by CJ7-Tim View Post
I am going to take the other side of this discussion. Many people simply repeat what they read someplace on some forum and have no direct experience with the AAL..
exactly!
all of his information i co-rect
blue jeep club member 174
2001 xj- 2 inch bb moabs
1998 zj 5.2- 245/75's moabs
91xjgawes is offline
post #15 of 24 Old 11-30-2008, 11:19 AM
bingolli
1993 XJ Cherokee
i really dont mean to hi-jack the thread but i feel that my question belongs here. i just replaced my leaf packs with new stock leaf packs, the old ones were sagging, not inverted but pretty much flat. i want to build a bastard pack with the main and second leaf from my old packs and the brand new leaf packs i just installed. i also want to add an extended 1.5" shackle. is this a bad idea? i dont want to ruin my new leaf packs
'93 sport - 32x11.5 Maxxis Buckshot Mudders - 4 inch homebrew lift - Rancho shocks - Safari Snorkel knockoff - KC slimlites - silverstars - Midland CB - K40 CB antenna - rooftop tent
bingolli is offline
aal , add a leaf , bastard pack , budget boost , lift blocks , saggy springs
Stupid Stupid Little Accident = Need Advice on Tow Hook Buying photonut13 XJ Cherokee Technical Forum 8 06-29-2008 12:02 AM
stupid stupid question...check engine light iwishihad1 XJ Cherokee Technical Forum 11 05-16-2007 09:17 PM
One Stupid Question...One not so stupid (I hope) xjrrrdx XJ Cherokee Technical Forum 1 08-02-2006 11:01 AM
stupid (maybe not that stupid) brake question dirt machine XJ Cherokee Technical Forum 10 05-02-2006 04:12 PM
Stupid, Stupid AOHell gumcrew2 XJ Cherokee Technical Forum 1 01-18-2006 11:57 AM
