calipher help - JeepForum.com
post #1 of 18 Old 05-05-2013, 02:42 PM Thread Starter
neng1987
calipher help
bought a new passenger side front calipher, the old one seized. so i went to install it and no matter what i do the top piston wont tighten down. I use new bolts washers that came with the new caliper. bottom piston tighten up with no problem. can anyone help? drove around the block n i could feel its deff not stopping good, dont have much pressure n have to press all the way down.
neng1987 is offline
post #2 of 18 Old 05-05-2013, 02:50 PM
Hudson
What do you mean by "the top piston won't tighten down"?
I'm sorry, but i don't understand what you're trying to say.
Did you bleed anything?
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #3 of 18 Old 05-05-2013, 03:03 PM
sluff28
1975 CJ5
I think he means the top bolt that holds the caliper on I had the same problem on my last axlel and I had to go get a bolt that was a quarter inch longer to get the threads to catch.
sluff28 is offline
post #4 of 18 Old 05-05-2013, 03:25 PM Thread Starter
neng1987
Yes the top bolt, it came with two bolts one for the top n bottom. I did bleed it out first. for sum reason it just wont catch the thread, i try screwing it in without the caliper n it catches fine, so a longer bolt will be it?
neng1987 is offline
post #5 of 18 Old 05-05-2013, 03:35 PM
Hudson
Got a C-Clamp or something you can try to pull it all together so you can get that bolt in?
I must ask, are you driving your jeep around with one bolt holding the caliper on?
Hudson is offline
post #6 of 18 Old 05-05-2013, 03:50 PM Thread Starter
neng1987
no im not driving around with one bolt, both bolt are in the top one arent tight, i could see the end of the bolt by the brake pad, idk why its all the way in but not tighten down on it.
neng1987 is offline
post #7 of 18 Old 05-05-2013, 03:53 PM
Hudson
So why doesn't the bolt screw in? Is there no thread left on the bolt? Is it just really tight? Any clue?
Hudson is offline
post #8 of 18 Old 05-05-2013, 04:31 PM Thread Starter
neng1987
Its a new bolt, im thinking the receiving end has the thread issue. the problem is it goes somewhat tight then it goes completely loose, it will keep repeating that process
neng1987 is offline
post #9 of 18 Old 05-05-2013, 04:40 PM
sluff28
1975 CJ5
on mine the problem was the bracket on the knuckle had some boogered up threads. so I needed a bolt that was 1/2 longer to catch threads. if I remember correctly 1/2 inch longer was a hair to long so a few spacer washers helped.
best of luck
sluff28 is offline
post #10 of 18 Old 05-05-2013, 04:52 PM Thread Starter
neng1987
okay thanks, my other issue is the brake pressure is there but i have to press really down to stop, im guessing once i fix the bolt issue it will fix that as well.
neng1987 is offline
post #11 of 18 Old 05-05-2013, 05:08 PM
xjdantheman
1993 XJ Cherokee
you need to loosen the bottom bolt and try again. but it sounds like the bolt is not going in straight like it should that is why you get the feeling like its tightening and then bam its loose again.
xjdantheman is offline
post #12 of 18 Old 05-05-2013, 05:34 PM
sluff28
1975 CJ5
and the pressure problem wont be fixed by fixing the bolt bleed the brakes in this order back passenger back driver front passenger front driver two people one in the cab one operating the bleed valve on the wheel fill the reservoir after each wheel. I had to do mine twice after by disc brake conversion but its much better now
sluff28 is offline
post #13 of 18 Old 05-06-2013, 01:27 PM Thread Starter
neng1987
Im a total noob to jeeps, why cant i just bleed the paseenger front, thats the one has the problem
neng1987 is offline
post #14 of 18 Old 05-06-2013, 01:44 PM
Hudson
Loosen the bottom bolt. Try to start both bolts at the same time and tighten them together.
If that doesn't work you might need to drill out the threads and heli-coil it.
You can't just bleed one brake because there will be air in the system.
Hudson is offline
post #15 of 18 Old 05-06-2013, 02:08 PM Thread Starter
neng1987
ok, which reservoir cap is for the rear brake? will the one closer to me be for the front brake
neng1987 is offline
