Quantcast cage q's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > cage q's
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 09-22-2004, 01:59 AM   #1
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
cage q's
What do you guys think of this?
http://www.rockhard4x4parts.com/cherokeexj.htm
I like where are the bars are posistioned, but I'm not sure if I like the hole bolt on thing. Also, do you think 1000 bucks is good, or do you think a custom fabricator can do a better cage for a cheaper price? Thanks
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
Old 09-22-2004, 02:14 AM   #2
silverxj2001
i would try to stay away from a bolt-in cage... just because... check out these two pre-bent/notched cages that are weld in. i would rather have the structural rigidity and peace of mind from a weld in cage than that of a bolt in one.
d and c extreme
http://dandcextreme.com/product.asp?pkID=126
t and j performance
http://www.tandjperformance.com/products-bpp-xj-cage.htm
2001 2-door XJ prerunner
6.5" RE
33x10.5" BFG A/T KO
15x8" rockcrawlers w/3.75" bs
hannemann 6" bulge flat top fiberglass fenders
bilstein 11" travel 5150's
RE XD trackbar / frame mount
RE adj. LCA/UCA's
beard triple thick limit straps
rusty's steering box brace
truckfarm pre-runner bumper
intake / exhaust
procomp lighting
system... yada yada yada
[URL=http://www.cardomain.com/memberpage/437678/1]PICS OF MY XJ[/URL]
silverxj2001 is offline   Reply With Quote
Old 09-22-2004, 02:29 AM   #3
GottaBeJeep
The setup looks ok. I like how the front mounts don't take up a lot of leg room in the front. Bolt on setups aren't as strong as welding, but for the weekend easy wheeler it isn't too bad. The mounting at the floor looks like the week point. It doesn't seem to tie into the frame rails at all. I thing $1000 is pretty steep compared to others I have seen in the $600-700 range. Personally, with your wheeling style (don't know you that weel, but I see you as a pretty avid wheeler), I think you might keep looking.
Rock Lizard Fabrications
...Off Road Armor that's "Tough as Scales"
GottaBeJeep is offline   Reply With Quote
Old 09-22-2004, 02:38 AM   #4
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
Hmm, I like the bottom one on T&J's page, thats 900 bucks, plus I'd need a welder to install it, but it looks awesome. Also, it does't affect anything on the inside as far as space. I like that one very very much.
That D&C ones looks great too, I just don't like the bar behind the seat, at least not for everyday use. I like to put my seat back alot, so maybe if I left that one bolt on it would be better. That would be great for shoulder harnesses.
Now, time to start saving
What do you think marty
Matt
MY XJ PICS
Old 09-22-2004, 07:50 AM   #5
homerscj7
Give these guys a yell...
http://www.swracecars.com/
They're down my way and will put together a cage to your specs for cheap. You just have to weld it in. It's where this one came from...
http://community.webshots.com/photo/113970585/113978407diIevM
I don't like the idea of a bolt-together cage either...kinda scarey
[size=1]
The road to destruction is paved with good intentions[/size]
homerscj7 is offline   Reply With Quote
Old 09-22-2004, 08:49 AM   #6
JJsKJ
2003 KJ Liberty
I ordered a cage from D&C last week. Seemed to be a good deal for the price.
Now if it would hurry up and get here!
03 SFA KJ ,Blue Mine
04 KJ, Khaki - Wifes
94 XJ, Blue - Son 1
99 TJ, Green - Son 2
HotRodOil.com
LOST JEEPS Club So-Cal Forum
JJsKJ is offline   Reply With Quote
Old 09-22-2004, 10:51 AM   #7
jeeponly
Get a bender and a welder and build your own.
Spring project:
D44 front
5.13s, Detroits, alloys, hi-steer, blah, blah, blah.....
jeeponly is offline   Reply With Quote
Old 09-22-2004, 11:35 AM   #8
silverxj2001
yeah the bar behind the seat is for mounting up a harness... it looks like it doesnt interfere with anything though...
6.5" RE
33x10.5" BFG A/T KO
RE adj. LCA/UCA's
intake / exhaust
procomp lighting
Old 09-22-2004, 12:06 PM   #9
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
How much was it? I didn't see a price. Also, how the heck do you weld them in, like the roof bars, how do you weld the top of that. I'm gonna talk to EndlessMtnFab, but first, I gotta get one of these.
Matt
MY XJ PICS
Old 09-22-2004, 12:10 PM   #10
silverxj2001
its $375. you dont actually weld the top bars to the roof, you just weld the cage together and then weld it to the floor. here's the supplied instructions right from d and c
http://www.dandcextreme.com/product.asp?pkID=129
6.5" RE
33x10.5" BFG A/T KO
RE adj. LCA/UCA's
intake / exhaust
procomp lighting
Old 09-22-2004, 12:19 PM   #11
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
Both your links for D&C don't work, but I figured it out. Damn for only 375 I'll deffinatly go for that one, unless you guys think this one is crap. That sounds like a really good price though. I really like that T&J one though, but thats alot of money, and it seems the other one is better.
Matt
MY XJ PICS
Old 09-22-2004, 12:19 PM   #12
Fullsizexj
Just remember one thing if you use a shoulder harness to the bar behind the seat, you must run cage supports under the seats and tie all the seat mounting into the cage and not the floor board anymore including your lap belt, reason is because in an extreem roll or something, the cage will have a tendency to seperate from the body portion of the vehicle and you don't want to be the joint trying to hold them together. Either you tie it all into the cage or you tie it all into the floor, not both
Fullsizexj is offline   Reply With Quote
Old 09-22-2004, 01:44 PM   #13
homerscj7
dewd, S&W adveritses 8pt cages for $149 and 10pt for $219
...seriously, call them
[size=1]
Old 09-22-2004, 02:02 PM   #14
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
Hey Eric, I called S&W, sounds good. Its only 219 for the XJ 10 piont cage They will also install it, but thatas extra. Thanks man, I'm gonna go with that, unless someone can tell me why not to.
Matt
MY XJ PICS
Old 09-22-2004, 02:40 PM   #15
joshbish
I personally don't see the point in an inside cage when you can put an external cage on it for about the same money and not only save your head, but also your rig. just my two cents.
joshbish is offline   Reply With Quote
  • XJ cage - Cherokee Technical Forum (5 replies)
  • exo-cage - Cherokee Technical Forum (10 replies)
  • Exo-cage - Cherokee Technical Forum (8 replies)
  • XJ Cage..... - Cherokee Technical Forum (21 replies)
Glock Forum
