C8.25 spring plate dimensions? - JeepForum.com
post #1 of 2 Old 07-25-2010, 06:26 PM Thread Starter
JGriff99xj
Hey guys, looking to find the dimensions on Chrysler 8.25 spring plates. I am going to make my own bumpstop version of these out of 3/8 plate.
JGriff99xj is offline
post #2 of 2 Old 08-27-2010, 08:31 PM Thread Starter
JGriff99xj
Nobody responded to my post so I got off Jeepforum and actually measured them myself haha. If you guys would like the dimensions to make your own I can try to get them up here for you. I got the dimensions and made a print in AutoCad to go by. I made the plates from 7" x 3/8" flat bar stock. I cut the pieces to 5 3/4" and drilled 1/2" holes for the U bolts to go through and the center pin for the springs should be drilled to about 5/8". Got them installed today with new longer poly bumpstops and everything works great. Went over some speed bumps and a pothole and no more tires in the fenders. Total cost was a clif bar, some water, pb blaster, some spray paint, a little electric, and a couple busted knuckles. I'm satisfied.
Spring Dimensions? NJSPEEDER XJ Cherokee Technical Forum 3 02-06-2009 10:27 PM
XJ Coil Spring Dimensions? HeepToJeep XJ Cherokee Technical Forum 10 01-28-2008 10:32 PM
Dimensions??? devile XJ Cherokee Technical Forum 6 11-22-2005 05:35 PM
Bed dimensions please. Junker MJ Comanche Technical Forum 2 06-02-2005 11:58 PM
I Need Dimensions jrskblx125 XJ Cherokee Technical Forum 18 10-21-2004 07:00 PM
