C4x4 Tow Hook Installation Writeup - Page 3 - JeepForum.com
post #31 of 31 Old 10-24-2009, 09:32 PM
Kevin108
I would not have gotten these things installed without this thread!
C4x4's instructions are like:
1. Remove bumper
2. Install plates
3. Install bumper
And yeah, it's nothing like that. The instructions they give you should be like the index for the real instructions.
I would say it takes far more than a basic hand tools to install this. In addition so wrenches and sockets I used an impact wrench, 3 different lengths of extensions, a universal socket for the bolt by the alternator, a drop light and an extra set of hands. I also had to cut one of the torx bolts that hold the bumper to the brackets. It and the speed nut had rusted into unity.
Bottom line: the hardware is great but the directions are severely lacking.
Originally Posted by Staffybull603 View Post
I figured out why you have the bolts going the way you do. I had to slightly notch the bumper mounting plate for the front bolt. The alternative would have been to use a shorter bolt there.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
c4x4 Tow Hook Pre-97 Install csouers XJ Cherokee Technical Forum 5 01-28-2010 06:38 AM
C4x4 tow hook ? backwoodz XJ Cherokee Technical Forum 1 02-20-2009 08:49 PM
c4x4 tow hook bracket install Beeker356 XJ Cherokee Technical Forum 2 12-29-2006 07:19 AM
C4x4 Tow Hook kit install questions viator XJ Cherokee Technical Forum 6 12-29-2005 11:43 PM
C4x4 Tow Hook Install Problem IntrepidXJ XJ Cherokee Technical Forum 14 12-29-2002 11:54 PM
