C4x4 Tow Hook Installation Writeup - Page 2 - JeepForum.com
post #16 of 31 Old 09-21-2008, 09:54 PM
Chocky
just a question...is it personal preference to trim the area underneath the hook? I see that you just slipped it thru the pre-cut hole there.
I was always assuming that that needed to be cut out completely.
Chocky is offline
post #17 of 31 Old 09-23-2008, 09:40 PM
mrtosh
2005 WK
Quick question on the bumper mounts, couldn't you just leave the mounts attached to the bumper and mount the bumper up while you were mounting the hook mounts? Like stated in the previous post?
'05 WK Limited QDII, Superlift 6", Bilstein struts,315/70/17 Duratracs, Gibson CB, Volant CAI, JBA UCA's, JKS quick disco, adj. Rear trac bar, 4xguard armor, Diablosport Intune, Xenondepot 6000k HID's, Putco Jet yellow fogs.
mrtosh is offline
post #18 of 31 Old 09-23-2008, 09:50 PM
4pointOH1998
2016 KL Cherokee
I left the mounts attached to the bumper. I put the brackets for the hooks on the frame rails and pretty much forced the bumper back on. Warning though, it took some muscle to get the bumper back on after
-Bryan- ΚΔΦ-MΘΣΝΔ
Fighting the rust since April '08...
4pointOH1998 is offline
post #19 of 31 Old 10-28-2008, 12:50 PM
RallyXJ
I have the hooks for this but I need to make the brackets. Does anyone know the dimensions of these?
RallyXJ is offline
post #20 of 31 Old 12-28-2008, 02:23 PM
jjg214
did you buy the hooks and brackets in a kit? if so, from where?
jjg214 is offline
post #21 of 31 Old 12-28-2008, 03:06 PM
4pointOH1998
2016 KL Cherokee
Here ya go http://jeepinoutfitters.com/scripts/...p?idproduct=40
-Bryan- ΚΔΦ-MΘΣΝΔ
post #22 of 31 Old 06-27-2009, 04:48 PM
winkosmosis
How exactly do you remove the endcaps? The other guides aren't clear, and this one doesn't mention them at all. I removed 3 or 4 screws but they won't move at all. It's like there is something holding them on besides the air dam.
Also, what is the best way to remove the air dam rivets? I've tried Dremeling them, but the centers seem to be some really tough metal
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline
post #23 of 31 Old 06-28-2009, 05:44 PM
winkosmosis
Got my endcaps off... Was missing the 4th screw.
But how do you get the left side L bracket on, with the steering box in the way of the bolts???
post #24 of 31 Old 06-28-2009, 05:51 PM
winkosmosis
BTW it seems to me like you should put the big washers behind the frame, since the metal is pretty thin. What good do they do on the cast iron brackets?
post #25 of 31 Old 06-28-2009, 06:49 PM
winkosmosis
Thinking about tying a metal wire around the screws, and pulling them through the holes. Is there anywhere they can fit through?? I can't picture threading a nut back there....
post #26 of 31 Old 06-28-2009, 10:37 PM
winkosmosis
I have discovered that pulling the screws through with wire works. Put the big washer on the screw, tie the wire around it, and pull through. The top one takes some work to get it through.
post #27 of 31 Old 06-29-2009, 08:55 AM
XJH-007
XJH-007's Avatar
Could I get some VIDEO of the actual wrench turning on each socket please?? I am lost on my install........
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #28 of 31 Old 06-29-2009, 08:07 PM
winkosmosis
Another thing... On the right side, the alternator is in the way, so you need a ratcheting box wrench. On the left side, the steering linkage is in the way, so you have to use an open ended wrench which takes forever. Why doesn't anyone mention these obstructions?
post #29 of 31 Old 06-29-2009, 08:33 PM
4pointOH1998
2016 KL Cherokee
Are we talking the same product here? My hooks/brackets were really easy to install
-Bryan- ΚΔΦ-MΘΣΝΔ
post #30 of 31 Old 10-20-2009, 09:26 PM
Kevin108
Originally Posted by Staffybull603 View Post
Shouldn't you have installed the bolts going through the hooks the other way so that the threads are inside the brackets and the only thing inside the hook is a bolt head?
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
c4x4 Tow Hook Pre-97 Install csouers XJ Cherokee Technical Forum 5 01-28-2010 06:38 AM
C4x4 tow hook ? backwoodz XJ Cherokee Technical Forum 1 02-20-2009 08:49 PM
c4x4 tow hook bracket install Beeker356 XJ Cherokee Technical Forum 2 12-29-2006 07:19 AM
C4x4 Tow Hook kit install questions viator XJ Cherokee Technical Forum 6 12-29-2005 11:43 PM
C4x4 Tow Hook Install Problem IntrepidXJ XJ Cherokee Technical Forum 14 12-29-2002 11:54 PM
