A/C Woes - JeepForum.com
post #1 of 6 Old 05-07-2013, 01:02 PM Thread Starter
defibvt
1974 CJ5
A/C Woes
Here is the back story. My a/c went out completely in 93 XJ with the 4.0L, nothing worked, just hot air. I had it diagnosed by a local reputable shop and was told that the compressor had disintegrated and that there were metal shavings throughout the system.
So, I got the bright idea that I could change out the whole system and fix it myself. My buddy and got it all done after about 3 weeks of working on it on our spare time. Our biggest conumdrum was what the D and S meant on the compressor. After some research, a phone call to the dealership, I was told the the D was for discharge and it was the high side and that the S was for suction and the low side. After all lines were hooked up, PAG oil put in the system, and R134a put in the system we figured we had it licked.
But no , For some reason the compressor does not want to kick on. Remember this is a new compressor. We jumped the compressor and are able to get to engage and work but hooking up to the OEM wiring does not work.
Today I changed out the relay under the hood and nothing happened. I am stumped. Any ideas are appreciated?
defibvt is offline
post #2 of 6 Old 05-07-2013, 02:08 PM
M35A2
1995 XJ Cherokee
Did you flush the system with the proper flush? If the comp came apart, you should put a new expansion valve as well as a receiver/dryer. Did you evacuate the sysyem before feeding it new freon?
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
post #3 of 6 Old 05-07-2013, 02:31 PM Thread Starter
defibvt
1974 CJ5
Everything is new in the whole system. The completely new system was brought down on vacuum and checked for leaks. PAG oil was added and then R134a. The system calls for 38 oz of R134. Our guages told us it was filled correctly and with have 3 empty R134 cans and 1 partially empty R134 cans we knew it was filled correctly.
defibvt is offline
post #4 of 6 Old 05-07-2013, 07:53 PM
M35A2
1995 XJ Cherokee
There's a 15a fuse somewhere in the system, don't remember if it's under the dash or in the box under the hood. That would be the easiest thing. Might be the relay too. I don't think these have a high pres switch, I think only a low pres. one. Was there metal in the system? Maybe the low pres switch is plugged/stuck telling the system it's low and not cycling the comp?
M35A2 is offline
post #5 of 6 Old 05-08-2013, 04:00 PM
ECL
Are you getting voltage to the electromagnetic clutch on the compressor?
Do you have continuity thru the electromagnet clutch to ground?
ECL is offline
post #6 of 6 Old 05-08-2013, 07:09 PM Thread Starter
defibvt
1974 CJ5
Forgive me for not posting responses. I was at work an unable to post. I will be replacing the low pressure switch and I don't think it has a high pressure switch, at least I can't find one. I will be checking on voltage next week after I work my stretch. Thanks for the ideas.
defibvt is offline
a/c
