***A/C Vacuum Canister Relocation?*** - JeepForum.com
post #1 of 5 Old 06-09-2010, 08:04 PM Thread Starter
Stopstaringatme
1995 XJ Cherokee
I put on a custom off road bumper on my XJ and i need to relocate the A/C vacuum canister that was located inside the stock bumper and was wondereing where i could possibly relocate this d*** thing under my hood possibly????:
Need to know asap showing the car to potential buyer on friday need answers FAST!!!
Thanks
Ian
The severity of the itch is inversely proportional to the ability to reach it.
Stopstaringatme is offline
post #2 of 5 Old 06-09-2010, 08:08 PM
Kettles
I just re routed the line and its just hanging out in the engine compartment, kinda inbetween the PDC and a/c hose (although I dont know if they are in the same location on your 95).
Basically you can just put it in the engine compartment wherever it will fit. Just dont bend the hose too far, i broke the line. Duct tape has worked so far, lol, the vents change a little slow now because I think its peeling off, so I think I need to fix it a little better.
Alternatively, you can screw it back into your offroad bumper with some self drilling screws.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #3 of 5 Old 06-09-2010, 08:14 PM Thread Starter
Stopstaringatme
1995 XJ Cherokee
i thought of screwing it into the bumper but there isnt enough room btween the bracket and the can itself to screw it in that way so ill just secure it somewhere inside the engine compartment thanks alot man i have so much work to do on this thing tomorrow before friday...i still have to put my fender flares back on even lol
post #4 of 5 Old 06-09-2010, 08:17 PM
Kettles
Good luck!
_=====o000o
Kettles is offline
post #5 of 5 Old 06-09-2010, 08:35 PM
Whistler31
1995 XJ Cherokee
I ended up zip tying mine to the coolant reservoir. I did yank all my A/C lines out though, it hasnt worked since I got it and the condenser was leaking.. It should still fit though. I carefully rerouted the line.
Whistler31 is offline
a/c , help needed
'99 XJ Vacuum Canister Relocation flashthunder XJ Cherokee Technical Forum 5 04-07-2009 07:07 PM
Vacuum Canister relocation Donerstude XJ Cherokee Technical Forum 3 12-19-2008 10:50 AM
vacuum canister relocation help... NEED HELP ASAP! 89SAFARIXJ XJ Cherokee Technical Forum 27 11-26-2008 09:51 PM
Vacuum Canister/Horn Relocation XtrailratedJ XJ Cherokee Technical Forum 6 08-27-2008 03:59 PM
where are the vacuum lines to the front vacuum canister??? Elliottm2333 XJ Cherokee Technical Forum 3 03-13-2007 09:26 PM
