A/C System: Need Info. - JeepForum.com
post #1 of 3 Old 06-08-2011, 12:16 PM Thread Starter
NS1999XJ
Hey everybody. I finally turned on the A/C in my Cherokee for the first time since I have owned it. Surprise, it blew out hot air. SOOOOO I bought the recharge kit from autozone and connected to the low port and turned the A/C to full blast and it got cold..... So I thought, coool ..... Well after getting back on the road running my errands, it started to get warm not hot though. I shut it off and rolled down my windows..... After getting too hot for that, I turned it back on and it got cold again then hot again..... I did this all the way to where I had to go... Whenever I turn the car off I can hear a hiss from the front of the car and a very quiet hiss from inside the cabin. I assume that its leaking somewhere but is there a way I can tell what part it is without putting the stupid dye into my system and seeing if its the evap core or the condenser??? Any help appreciated.
I've got a 1/4 tank of gas, a pack of smokes and I don't get paid until next week. Lets go!
NS1999XJ is offline
post #2 of 3 Old 06-08-2011, 06:05 PM
davsfsj3xjs
1987 FSJ Wagoneer
Sounds like you may not have put enough refrigerant in. Try another can, because if it leaked out, it would not get cold again, at all.
4x4s are what you make of them, or do with them. No guts - No glory ;')
davsfsj3xjs is offline
post #3 of 3 Old 06-09-2011, 03:24 PM
AZ Jeff
2014 JK Wrangler
Dye-type leak detection rarely works on finding evaporator leaks on XJ's. This means you need the services of a pro to at least FIND the leak, even if you want to fix it yourself.
Have a professional shop pull a vacuum on the system and see if it holds vacuum or not. If it does not, then the only SURE FIRE way to find the leak(s) will be with a partial recharge and a "sniffer".
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
1991 Cherokee Limited factory Security system and/or NuStart System pathfinder76 XJ Cherokee Technical Forum 1 10-01-2014 10:47 AM
Brake system info dieselkiller XJ Cherokee Technical Forum 7 11-20-2009 07:43 AM
Is the AC system and the engine cooling system connected firedogut XJ Cherokee Technical Forum 8 07-17-2009 11:47 AM
Closed cooling system to Open system? motu1983 XJ Cherokee Technical Forum 7 08-02-2007 10:39 AM
rancho lift system vs skyjackers lift system cg2xj XJ Cherokee Technical Forum 8 03-29-2006 12:27 PM
