a/c stopped working after a week in Vegas - JeepForum.com
post #1 of 3 Old 08-20-2012, 04:24 PM Thread Starter
unistar
So I just moved to Las Vegas from Utah and one week into it my a/c goes out on my 2001 cherokee. It was blowing cold one day and the next it was hot. The components in the engine bay check out ok I think. The clutch on the compressor is engaging like it should. I checked some vacuum lines and they were pulling pressure. I figured it leaked the refrigerant out but the hardline going onto the firewall still gets ice cold. In the cabin everything is blowing out the right vents and all. The only problem is if I turn the knob from cold to hot it gets hot but when I turn it back to cold it stays hot. Is there a door somewhere that is stuck so it is only diverting hot air? any ideas?
unistar is offline
post #2 of 3 Old 08-27-2012, 12:04 PM Thread Starter
unistar
Bump. Any ideas out there?
unistar is offline
post #3 of 3 Old 08-27-2012, 02:02 PM
AZ Jeff
2014 JK Wrangler
Your blend door probably is not moving. The motor for the door is on the bottom of the heater box above the trans tunnel. It is attached by three screws to the heater box. Start by taking the motor off the blend door shaft and see if it moves freely. If it does, then I suspect the axle for the blend door is broken and that means the heater box must come out to fix it.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
a/c , air conditioning , las vegas
Horn stopped working guttafixit XJ Cherokee Technical Forum 9 09-06-2010 12:41 PM
A/C Stopped Working Dannyboy18 XJ Cherokee Technical Forum 4 05-29-2008 09:28 PM
Guages Stopped Working nitroman XJ Cherokee Technical Forum 5 12-30-2007 06:21 PM
Found out why my aux fan stopped working CraigAllen XJ Cherokee Technical Forum 3 06-09-2007 12:56 PM
ABS stopped working jaardesign XJ Cherokee Technical Forum 6 12-15-2005 03:35 PM
