A/C Stopped Working - JeepForum.com
post #1 of 5 Old 05-29-2008, 11:53 AM Thread Starter
Dannyboy18
A/C Stopped Working
I tried my A/C for the first time all year yesterday and it does not work. All it does it blow air out the vents rather than click the compressor and fan on. As all of you know, when you turn the A/C on you DEFINITELY hear it working the entire time because of the fan noise... I have none of that.
Note: the A/C is only two years old due to a front end accident.
I'm guessing sensor or something related...? Ideas?
Thanks.
--Dan
1999 Cherokee Sport - Black; 4.0L AW4, NP231 w/ D30 and 8.25C.
RE 3.5" Super Ride w/ full packs (4* shims) + OME shocks + RE SYE w/ Tom Woods CV
Yukon 4.10s
AR Baja Alloy Wheels - 15x8 + Bridgestone Dueler Revo A/Ts - 31x10.50x15
TeraFlex Adj. Trackbar + TeraFlex Quick Disconnects & WARN T-case skid
Dannyboy18 is offline
post #2 of 5 Old 05-29-2008, 12:00 PM
tntempest
You are low on freon, you could bypass the low pressure switch to make sure your compressor is good, but you more than likely have a slow leak where they tied the old and new together. Just go to autozone get one of the tall r134 cans with the gauge and turn the ac on and fill er up. That will cost you $20, or you can take it to whoever fixed it for you last and they will charge you $500. You may have to do this every spring, but at $20 a year it is worth it.
2004 Wrangler Rubicon
tntempest is offline
post #3 of 5 Old 05-29-2008, 08:07 PM Thread Starter
Dannyboy18
Alright I will try and do this on Saturday or Sunday. However, could you please explain the procedure for recharging the A/C on the XJ? I've never done this before.
Yukon 4.10s
post #4 of 5 Old 05-29-2008, 08:28 PM
tntempest
It is very easy, locate the low pressure port on the Aluminum tube coming off the evaporator near the firewall, it has a cap on it. It is on the passenger side.
Buy one of the Tall R134 cans with the built in gauge at the parts store, should be $20-24 dollars. Will be marked max cool or EZcool or some other brand. Read the instructions on the can on how to pierce the can so it is ready to go, the one I used this weekend had a trigger and I liked that verses a valve. Turn the AC on max and connect the can to the low port (it is a quick connect snap coupling, it will not snap on the high port so don't worry. The high port is up on the compressor. A short time after opening the valve or trigger on the can it should start kicking the compressor on. Read the gauge after you let off the trigger or valve and that is the real pressure, it will spike higher when you are pulling the trigger. Depending on how low it may take several minutes to fill up to the full point. I filled mine to about 5 pounds below the full mark on the gauge. I am not sure how accurate those gauges are so I was being conservative. Anybody have anything else to add?
Oh, wear safety glasses, and don't leave the freon can in a hot closed car, theres a good story every time.
post #5 of 5 Old 05-29-2008, 09:28 PM
AZ Jeff
2014 JK Wrangler
One word of caution--with AC systems, there is such a thing as TOO MUCH refrigerant. EVERY YEAR on the various Jeep forums, some poor sucker keeps adding refrigerant to the system WAY PAST the allowable limit, and winds up hydrolocking his compressor and REALLY trashing the system.
If you cannot get it to run with the "DIY" approach suggested previously, I STRONGLY suggest you pay a pro to at least DIAGNOSE your problems, and then fix whatever is "bad" according to that diagnosis, and then pay the pro to evacuate/fill the system correctly.
AC systems are sensitive to being filled properly, and can get REALLY screwed up by not following proper procedures and using proper tools.
Be forewarned......
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
Speedometer stopped working Khary23 XJ Cherokee Technical Forum 10 12-16-2008 06:54 PM
speedo stopped working AlexsXJ XJ Cherokee Technical Forum 3 01-12-2008 02:07 PM
Found out why my aux fan stopped working CraigAllen XJ Cherokee Technical Forum 3 06-09-2007 12:56 PM
speedometer stopped working?! cucr3 XJ Cherokee Technical Forum 7 03-20-2006 03:28 PM
ABS stopped working jaardesign XJ Cherokee Technical Forum 6 12-15-2005 03:35 PM
