A/C question - JeepForum.com
post #1 of 9 Old 06-15-2013, 01:12 PM Thread Starter
josh1011
A/C question
Is there a way to switch r12 over to 134a
josh1011 is offline
post #2 of 9 Old 06-15-2013, 06:34 PM
hshark
Yes change fitting, evacuate system, change compressor oil etc. Do a search online it's not hard. Honestly though if you could get a hold of some R12 for cheap I would stick with it. Good luck!
hshark is offline
post #3 of 9 Old 06-15-2013, 09:48 PM
djb383
Yep, as stated, do a little searching. Not much more than removing old refrigerant, cleaning/flushing old oil out of all components, installing new accumulator/dryer, orifice tube and adding new oil and refrigerant......in proper amounts of course. I've done 2 conversions and see just as cold temps with r134a as r12.
Man Law - hoods should be raised at least once a week.....have a look see.
djb383 is offline
post #4 of 9 Old 06-16-2013, 10:07 AM
AZ Jeff
2014 JK Wrangler
Yse, conversion to R134a is quite "do-able". You will need new refrigerant, new R134a compatible oil, and new o-rings on all fittings, along with a new accumulator.
I disagree with "djb383" in that you will NOT need to remove all the old oil, as it tends to settle in the low spots in the system and won't circulate with the R134a anyhow. A flush prior to evacuation and recharge would not be a bad idea anyhow.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #5 of 9 Old 06-16-2013, 07:55 PM
MarkwithaK
I have to respectfully disagree with this. The oil in 134A is not compatible with the oil used in R-12 and therefor all components should be replaced. That would include the compressor as it was specifically designed to function based on the properties of 12, I know people aren't going to do that but as I said it wold be the correct way to do it. All other components will need to be replaced however. Any easier route would be to replace the R-12 with R-414B (also called Hot Shot). It is what we use in the HVAC/R industry to re-charge old R-12 systems because it is a direct drop in replacement. Locate a commercial HVAC/R tech and see if he would charge your system.
Also keep in mind that if you open up your system you will need to pull a vacuum on it before re-charging it with any refrigerant.
MarkwithaK is offline
post #6 of 9 Old 06-16-2013, 10:15 PM
AZ Jeff
2014 JK Wrangler
Originally Posted by MarkwithaK View Post
I have to respectfully disagree with this. The oil in 134A is not compatible with the oil used in R-12 and therefor all components should be replaced. That would include the compressor as it was specifically designed to function based on the properties......
While your approach is certainly effective, its very conservative and wholly unnecessary on a system that was in decent shape prior to conversion.
I have converted several older systems quite sucessfully without changing compressors (but they were functioning normally before conversion.)
I never suggested the proper oil should not be added to the system in the proper amounts, but leaving some old R12 type oil in the system is not automatically bad, if the amount is not excessive.
AZ-Jeff
AZ Jeff is offline
post #7 of 9 Old 06-18-2013, 03:02 PM Thread Starter
josh1011
would it be easyer to use "freeze 12" i found on amazon
josh1011 is offline
post #8 of 9 Old 06-18-2013, 03:06 PM Thread Starter
josh1011
another thing thats off topic what does it mean if when i start up my jeep at idle it makes a quiet rattle and the motor shakes a bit but then at about 1000 rpm it clears out and runs smooth. keep in mind the check engin light is off and the oil may need to be changed soon.
josh1011 is offline
post #9 of 9 Old 06-19-2013, 03:36 AM
hshark
I've never heard anyone removing there compressor running r12 and replacing it completely just because of the r134 conversion. I'm not saying it doesn't happen, but if your compressor works fine just have it switched over fallowing proper protocol. Again I would just stick with R12 if you could locate it online or use the compatible version as stated above. Honestly it seems more cost effective to leave as is. Good luck!
hshark is offline
