a/c problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > a/c problem
Rough Country Lift Kits and Parts!RIGID LED Light Blowout Sale - All Sizes, All Series, all Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerrai
Unread 05-04-2012, 10:47 AM   #1
jeepchick1013
a/c problem
i tried to charged my ac but the gauge on the hole kept going in the red. so i took it to a shop had the system evacuated and dye injected to find a leak. no leak found. its been about a month and its not cold anymore again. took it back to the shop and they said there was no leak and it could be behind the dash. but theres no smell so i dont see how it could be behind the dash. any ideas?
jeepchick1013 is offline   Reply With Quote Quick reply to this message
Unread 05-04-2012, 11:22 AM   #2
DerMeister
You won't smell it. Do a search for Evaporator.
They leak all the time, they did re-charge it when they put dye in it yes? If you lost it in a month you have a good leak. A sniffer would confirm it's from the evaporator, the part behind the dash.
Give yourself a day or two, buy a new evaporator, heater core, and drier, and search the forum for some write ups.
I've got to do the same thing this summer.
DerMeister is offline   Reply With Quote Quick reply to this message
Unread 05-05-2012, 08:30 AM   #3
Weebur
1997 XJ Cherokee
If your evaporator is leaking (probably is) and you have dye in your system then the shop should have checked the HVAC box drain (passenger side firewall underneath the cannister) for the dye. The refrigerant/dye will mix with water formed on the evaporator and make its way to the drain.
You or your shop also need to check if one or both of the Schrader valves are leaking. They are the valves under the caps for the low and high pressure side of the system. They are often over looked and very often leak on older vehicles. They can sometimes be tightened up a bit and can even be changed without losing the charge (with a specialty tool).
You can buy a decent UV light on the Internet for about $20 and check the drain tube yourself.
Replacing the evaporator is a big job as the whole dash has to come out. I've seen dealer quotes run from $1,000-1,800. I did mine and it took me a whole weekend.
Weebur is offline   Reply With Quote Quick reply to this message
Unread 05-05-2012, 05:55 PM   #4
Saudade
1988 XJ Cherokee
A leak is a leak regardless of where it is. Sounds like the shop didn't test it properly. I'd suggest going to another one.
What year is it? You want to be *ABSOLUTELY SURE* it's the evap before attempting to change this out.
Saudade is offline   Reply With Quote Quick reply to this message
Unread 10-24-2014, 01:09 PM   #5
SpideYJeep
jeepchick1013 - did you ever resolve this?
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline   Reply With Quote Quick reply to this message
Unread 10-25-2014, 04:39 PM   #6
jeepchick1013
No I didnt. The shop couldnt figure it out either. I ended up selling it. I didnt have money to deal with the a/c at the time.
