A/C Only Blows Hot Air, Plenty of Freon.... - Page 2 - JeepForum.com
post #16 of 22 Old 06-28-2009, 04:43 PM Thread Starter
NighthawkMDX
Thanks for the suggestions, I will work on the car this week and see what I find.
If the clutch is slipping will it still engage/spin when the car is running?
NighthawkMDX is offline
post #17 of 22 Old 07-29-2012, 07:34 PM
scottsilvia82
What did you figure out?
scottsilvia82 is offline
post #18 of 22 Old 07-29-2012, 07:44 PM
MJR
MJR's Avatar
1988
Is there a problem you have?
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #19 of 22 Old 07-30-2012, 07:27 PM
scottsilvia82
Yes! My fan clutch is bad! Same exact problem! But the problem indicates multiple problems. Moisture in the system could freeze and cause the same problem, the low/high pressure switches could be bad, ect. I have a good way of testing it all. Just wondering if you fixed it. I am drawing down my system in the morning to replace the compressor and clutch. My cluch works when it wants and cuts out when I don't want it to. I have a full rig for AC systems so it makes it easy to trouble shoot. Let me know if yours is working!
Scott
post #20 of 22 Old 07-30-2012, 07:44 PM
MJR
MJR's Avatar
1988
But a XJ has an aux electric fan for A/C unlike say a YJ.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #21 of 22 Old 05-03-2013, 02:11 PM
RadioAnna
My 2004 Wrangler X blows hot from A/C
Hi. The clutch isn't turning. We are testing the low pressure switch, but we aren't sure what the norms should be. I read somewhere on here of how to jump past the pressure switch to see if the clutch would start spinning. Can someone help me? I need to take this Jeep to Georgia in a few weeks and we must have A/C.
I dont think there was ever a leak, because trying to top of the freon it took hardly any. No we haven't had it vacuumed. I'd rather not waste the 30 bucks on freon to do that. We aren't getting readings that make any sense from our multimeter untit. we expect it to read 5 volts, and then something else for ohms. Confused.
Please help. Thanks.
RadioAnna is offline
post #22 of 22 Old 05-03-2013, 02:35 PM
MJR
MJR's Avatar
1988
The newer vehicles don't have a sight glass so the only way to make sure the charge it not over/under to to evacuate it and weight what goes back in. If you have something in the system the clutch should kick in. I can't remember off the top of my head whether or not there's one or two pressure switches on a TJ, I can look later. A low pressure one would prevent the clutch from engaging if there's no pressure and also cycle the compressor so as the evaporator doesn't freeze up. A high pressure switch is suppose to prevent compressor damage and system venting should the pressure get too high.
Jumpering the low pressure switch with the a/c on should cause the clutch to engage. There is a relay in the PDC underhood for it and maybe check the fuses.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
Plenty of flex! E-Dubs88XJ XJ Cherokee Technical Forum 5 09-30-2008 11:21 AM
Plenty turny No Sparky....Possible CPS? bcrmartin XJ Cherokee Technical Forum 7 08-04-2008 07:31 PM
Just got my Jeep, plenty of problems bradlovespie XJ Cherokee Technical Forum 9 06-14-2006 10:12 PM
No fuel....Plenty spark DVM04 XJ Cherokee Technical Forum 7 02-26-2006 02:56 PM
Newbie, with plenty of questions theone13 XJ Cherokee Technical Forum 7 02-12-2005 05:09 PM
