A/C to OBA conversion write up -PICS - Page 8 - JeepForum.com
post #106 of 297 Old 03-05-2008, 11:57 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
Originally Posted by RuffedUpXJ View Post
I finished my setup and its works great. Thanks Matt.
No prob man, glad to hear you got it done.
RussoGuitar is offline
post #107 of 297 Old 03-12-2008, 06:18 PM
sitdwnandhngon
1987 YJ Wrangler
great looking work, i would like to make one for the yj sometime.
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep View Post
4.2 has 0.2 more!
sitdwnandhngon is offline
post #108 of 297 Old 03-17-2008, 05:04 PM
cox_xj
1997 XJ Cherokee
ok i was thinking today
me being in the automotive field, and loving anything that adds power (ie BOOST)
when air is compressed it creates heat, hot air is not dense air, that is why turbos run intercoolers, and supechargers run aftercoolers
anyone have any idea how effective a cooler placed on the outlet line would be?, would it effect anything in the first place?
im just thinking outloud
cox_xj is offline
post #109 of 297 Old 03-31-2008, 03:53 AM
enil01
enil01's Avatar
This looks great, so I'm working on stealing your idea. I was just wondering though since I suck at wiring if you or anyone could draw up a quick diagram for powering this thing. Specificially if I didn't have A/C to begin with. Thanks.
'93 4.0L YJ Becky
RE 4.5" XD lift | 33" TRXus M/Ts | Warn M8000 | Herculined | OBA
_|_
--X-X-(_)-X-X--
<3 EP-3Es
enil01 is offline
post #110 of 297 Old 04-06-2008, 11:44 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
its simple... just need 12v from the battery to a on/off switch.. the switch goes to the pressure switch and from the pressure switch to a/c clutch.
post #111 of 297 Old 06-07-2008, 10:16 PM
Ginis
1989 XJ Cherokee
Nice write up, after lookin at the ac compressor you have and the one thats in my 89 they are diffrent. so my question is.. you guys think that my will this install be the same with mine as his? minor changes im sure but im talking anything signifiant.
1989 Cherokee 4.0L
AW4 NP242
3" Rough Country Lift - Generic 31s on junkyard rims
Ginis is offline
post #112 of 297 Old 06-08-2008, 08:37 PM
Flexin' XJ
Flexin' XJ's Avatar
1995 XJ Cherokee
Just what fittings you use to connect to your compressor. That should be it.
On a side note, I don't know if it has been mentioned earlier, but I also removed my a/c condenser since it is no longer needed and it will allow more airflow through the radiator.
1995 Cherokee 4-Door
4.0 AW4
4.5" RC System
JKS Discos
JKS Adjustable Track Bar
JCR 1-Ton Steering Conversion
Edelbrock Ceramic Header w/full 2.5" exhaust
33x12.50x15 SSRs
Aussie in front, LSD in rear
Death Wobble
Member GLFWDA
Flexin' XJ is offline
post #113 of 297 Old 06-08-2008, 08:56 PM
eflores
1989 XJ Cherokee
what about using the condenser as an after cooler?
AEKDB
Leaky sunroofed XJ member #1
The United States of America July 4, 1776 - November 4, 2008 RIP
eflores is offline
post #114 of 297 Old 06-08-2008, 08:59 PM
HeepToJeep
1982 CJ8
That makes me wonder..........with a few plumbing changes couldn't the ac condenser be used as a trans cooler?
Wm
HeepToJeep is offline
post #115 of 297 Old 06-08-2008, 09:26 PM
eflores
1989 XJ Cherokee
ok im hijacking but the question was asked...and the answer to trans cooler out of an ac condenser is no. trans coolers have "tanks" and several "cores" running out of them so flow is not decreased any.....ac condensers have one line in thats runs back and forth and remains one line from top to bottom start to finish...in short they dont flow enough...just finished my flow and pressure testing on one off my 91 parts xj. and those are my findings
AEKDB
eflores is offline
post #116 of 297 Old 08-07-2008, 04:45 PM
XJCutter
1995 XJ Cherokee
Help on hooking up the toggle switch....
I've read the thread over and over and I think I have everything understood except where to wire into the a/c clutch. Could you please take a picture of where all your wiring connects that would be helpful.
Thanks
XJCutter is offline
post #117 of 297 Old 08-08-2008, 04:31 AM
Flexin' XJ
Flexin' XJ's Avatar
1995 XJ Cherokee
Thanks
I just cut the factory compressor clutch connector off the vehicle side of the harness and spliced that end onto my wire going to my pressure switch. That way I can connect and disconnect like normal.
I then wired a toggle switch that went from B+ to the pressure switch and then from the pressure switch into the vehicle and mounted it to the dash. Then I grounded the other side of the toggle switch to a ground point under the dash.
When the toggle switch is turned on, it sends power to the pressure switch which then turns the compressor on if the pressure is below the set pressure.
I may be forgetting something. I had to remove all the parts last year because the vibrations snapped a couple fittings off and I lost my inlet filter and my water seperator bowl cracked and leaked air.
I want to rebuild it sometime and I will use a better plumbing system.
Read throught this article. I got most of my information from here.
http://jeep.off-road.com/jeep/articl....jsp?id=257802
I did some things differently. There is a schematic for both wiring and plumbing. I used a toggle switch to turn it on or off.
4.0 AW4
4.5" RC System
JKS Discos
33x12.50x15 SSRs
Death Wobble
Member GLFWDA
post #118 of 297 Old 08-08-2008, 01:03 PM
XJCutter
1995 XJ Cherokee
Thanks so much. That link is alot of help. It goes into pretty much every detail needed. I'm jealous of the your low cost. I'm already at least a hundred dollars more than you due to having to pay for the refrigerant to be drained and full price for a tank, which doesn't come with a pressure switch. But what can you do......It'll still only run my about two fifty so not too bad. I just got my rig and have to fix a few things, but I can't wait to get it off road in the Uwharries and see what it can do. I might even half to plug in an air grinder and trim a few body panels while I'm out there.
XJCutter is offline
post #119 of 297 Old 09-09-2008, 12:28 PM
Mattpar
1997 XJ Cherokee
I bought an a/c to oba system from someone parting out his YJ.
My Jeep is a 97 Cherokee 4dr 4.0L
How did you guy run your lines to the back of your jeep? I dont wanna cut holes where water might leaking into the cabin during water crossings.
Mattpar is offline
post #120 of 297 Old 09-09-2008, 02:03 PM
eflores
1989 XJ Cherokee
cut a hole and use a rubber grommet/silicone lube....and rubber hose when you get that far
AEKDB
eflores is offline
ac , ac to oba , compressor , conversion , oba conversion , sanden , xj
ZJ Rear Disc Conversion to 8.25" Write Up - The Whole Truth!!! TPI Monte SS XJ Cherokee Technical Forum 47 08-21-2013 09:34 AM
LED Panel Lights Conversion Write-up Islandroaddie96 XJ Cherokee Technical Forum 24 06-13-2011 05:50 AM
waggy front conversion write up? T4STE XJ Cherokee Technical Forum 9 01-12-2007 08:57 AM
8.25 rear disc conversion - Write up AMK XJ Cherokee Technical Forum 5 08-05-2004 10:00 AM
8.25 rear disc conversion - Pics & Write up soon AMK XJ Cherokee Technical Forum 12 08-04-2004 05:15 PM
