A/C to OBA conversion write up -PICS - Page 7 - JeepForum.com
post #91 of 297 Old 01-16-2008, 11:48 PM
HeepToJeep
1982 CJ8
Great problem solving and write up! I was wandering around the shop a few nights ago scoping and scrounging parts off a few engines for that exact same project. On several occasions I've been pelted by broken or jammed airlines that were snapping at my @ss like Indiana Jones so I believe the one main difference in my system is that all of my onboard 'plumbing' will be hardline tucked into the framerail. I'd be mortified if a line popped, ripped an interior panel loose and beat the hell out of my passenger(s)
Originally Posted by Timo_90xj
I relocated my alt. up to where the compressor is usually.
Excellent idea, do you have any write up info or photos for us?
Wm
HeepToJeep is offline
post #92 of 297 Old 01-22-2008, 06:12 PM
xcannibalx
A little off topic, i searched the net, and didn't have fantastic results.
I'm putting a TBI 350 into my jeep, and wondering if the stock AC pump on Chevy works in the similar manner as the jeep (aka, using the tool oiler...etc)
xcannibalx is offline
post #93 of 297 Old 01-22-2008, 06:18 PM
Jeepthing88
1994 XJ Cherokee
well done man! great work
94 Cherokee Sport
3" Rusty's Full Spring Pack
31X10.50 BFG Mud Terrain's on Crager Soft 8's
Jeepthing88 is offline
post #94 of 297 Old 01-23-2008, 02:45 PM
TxRex
TxRex's Avatar
1997 XJ Cherokee
I was wondwering what I was going to use that useless a/c compressor for! I copied your parts list, but where did you get your parts from? While my girl is down I want to do this mod while waiting on UPS to deliver my other parts!
_________
[l_|__\_i__\,__
l--___--[=lllllll=]
()_)' '()_)---)_)
1997 XJ- 3.5 Skyjacker + 31" Pro Comp All Terrains
RIP - 1988 YJ - Gone but not forgotten
TxRex is offline
post #95 of 297 Old 01-23-2008, 05:34 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
it depends, if its a roatary then yes, if its a piston compressor then it should hold oil in the crankcase.
RussoGuitar is offline
post #96 of 297 Old 01-23-2008, 05:36 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
The tank i got on ebay but can be bought on quadrtec, the manifold came from www.northerntool.com, and pressure switch was from quadratec. Everything else was bought at a hardware store.
post #97 of 297 Old 02-17-2008, 01:23 AM
asp87
awesome thread. lots of great ideas. like everyone else, too bad i have good AC.
i'm gonna be cutting out my rockers and welding in some big square tubing, think i'm gonna tie the tubes together and make them my tanks, somehow. they won't be compressed for a long time, but someday.
any thoughts on putting in a valve that you could put on a switch that could go between running AC and compressing air?
98 XJ, perpetually on jackstands
asp87 is offline
post #98 of 297 Old 02-17-2008, 06:45 AM
Flexin' XJ
Flexin' XJ's Avatar
1995 XJ Cherokee
It is possible but not very cost effective. Once you open the system, you will lose the freon and then you won't have AC. You could possibly T-off both lines at the compressor with a valve on each of the 4 lines. Then open the AC valves when you want AC and the air valves when you want air. But each time you do that, you will lose some freon that is trapped between the AC line and the compressor. Use the air enough times, you will lose all the freon. You would have to buy some AC manifold gauges to check the pressure in the system and to tell if you need to recharge your AC system.
You would also need to get valves that don't have any plastic in them since the plastic may not be compatible with r134-a freon. The freon might eat the plastic then you will have leaks.
1995 Cherokee 4-Door
4.0 AW4
4.5" RC System
JKS Discos
JKS Adjustable Track Bar
JCR 1-Ton Steering Conversion
Edelbrock Ceramic Header w/full 2.5" exhaust
33x12.50x15 SSRs
Aussie in front, LSD in rear
Death Wobble
Member GLFWDA
Flexin' XJ is offline
post #99 of 297 Old 02-17-2008, 09:47 AM
mall_crawler
all i can say is GREAT write-up!!!!!!
[ ] lllllllllll [ ]
The Trail Never Ends.....
mall_crawler is offline
post #100 of 297 Old 02-17-2008, 10:14 AM
cox_xj
1997 XJ Cherokee
just wondering hows it holding up? have you made any changes? do you plan on any changes? what type of use has it seen?
cox_xj is offline
post #101 of 297 Old 02-17-2008, 07:12 PM
MTY Mouse
1989 XJ Cherokee
Next mod, here I come....
MTY Mouse is offline
post #102 of 297 Old 02-25-2008, 09:26 AM Thread Starter
RussoGuitar
1989 XJ Cherokee
Sorry must have missed this.. But its been holding up great and i use it once a week atleast. Especially with the wet conditions with the snow/melting snow. Everyone im with, normally a group of about 4, airs down and then i air them back up. My only issue has been the fact that on really cold days, like in the 20's, a couple of the exterior fittings leak a little bit, but on warm days no issue.
post #103 of 297 Old 02-26-2008, 01:35 PM
GS450LZ
M. Nace
GS450LZ's Avatar
1990 XJ Cherokee
Air management for conversion to OBA
Thanks Russo for this great write up. I'm starting my conversion next weekend. I found a website that provides parts and air management materials at a reasonable price. Actually, very reasonable. I've already ordered my tank, pressure switch and gauges from there. They specialize in air suspension setups, but the parts can still be used for OBA setups. check it out.
https://www.truckinsuspension.com/
GS450LZ is offline
post #104 of 297 Old 03-05-2008, 08:54 PM
RuffedUpXJ
RuffedUpXJ's Avatar
1988 XJ Cherokee
I finished my setup and its works great. Thanks Matt.
88 XJ Red
| 5" of lift | Custom Bumpers | Black Rockcrawlers with 35x12.50 BFG MT's | Custom Rock Rails | Homebrewed OBA | Custom Roof Rack Loaded | Tube Doors |
Play 4x4Country.
RuffedUpXJ is offline
post #105 of 297 Old 03-05-2008, 09:42 PM
HCA-Bronco
D*&m dude that is a great write up, I can see what Mod I'm doing next...
1995 Jeep Cherokee Country
4.0l I6
Ohh the Wife won't let me Get what I want " I know I'm Whipped"
HCA-Bronco is offline
ac , ac to oba , compressor , conversion , oba conversion , sanden , xj
ZJ Rear Disc Conversion to 8.25" Write Up - The Whole Truth!!! TPI Monte SS XJ Cherokee Technical Forum 47 08-21-2013 10:34 AM
LED Panel Lights Conversion Write-up Islandroaddie96 XJ Cherokee Technical Forum 24 06-13-2011 06:50 AM
waggy front conversion write up? T4STE XJ Cherokee Technical Forum 9 01-12-2007 09:57 AM
8.25 rear disc conversion - Write up AMK XJ Cherokee Technical Forum 5 08-05-2004 11:00 AM
8.25 rear disc conversion - Pics & Write up soon AMK XJ Cherokee Technical Forum 12 08-04-2004 06:15 PM
