A/C to OBA conversion write up -PICS - Page 4 - JeepForum.com
post #46 of 297 Old 10-21-2007, 05:12 PM
cox_xj
1997 XJ Cherokee
the 'box' at the firewall is from the evap, yes that line can go
the line running to the 'radiator' runs to the condensor (in front of radiator) yes it can be removed
the black cylinder and any lines running to it can be removed as well
not sure on the wiring
cox_xj is offline
post #47 of 297 Old 10-21-2007, 05:59 PM
rocketman121
Cool, was just a little hesitant on completely removing those things, now I can.
One the other hand - I took the two lead hoses to home depot. Looked for fittings to go from the compressor to standard 3/4 NPT, but had no luck. Anyone know if these are Jeep specific?
-87 XJ 4.0 5spd, 2"BB, 31" BFG ATs on 15x8 Eagle 058s, trimmed and doorless
-01 TJ 4cyl auto FT 3" lift 33" Goodyear AT/S & BFG muds herculined tub
rocketman121 is offline
post #48 of 297 Old 10-21-2007, 07:22 PM
eflores
1989 XJ Cherokee
really very cool but its too bad my A/C still works and i DD mine
eflores is offline
post #49 of 297 Old 10-21-2007, 07:56 PM
hacked96
To keep from overheating the hoses from the compressor, I simply used the stock hoses which can handle the heat, just cut them in the metal section back passed the rubber section and slip air hose over them and clap, simple and no heat issues.
hacked96 is offline
post #50 of 297 Old 10-22-2007, 06:20 AM Thread Starter
RussoGuitar
1989 XJ Cherokee
Are you going to re use the A/C hoses? I think im lost a little, haha. If your taking the A/C fittings off your compressor like i did (mine were on the back though) you need a 3/4 to 3/8 or 3/4 to 1/4 NPT pipe reducer. It will be tricky for you cause youll need to have somthing with an elbow right away to clear the hood. When you said 3/4NPT did you mean 1/4 NPT? If your leaving the A/C fittings then im pretty sre those are just regular NPT threads, not sure of the size, but maybe take the whole valve fitting thingy off the compressor and bring it in to homedepot to find the fitting.
RussoGuitar is offline
post #51 of 297 Old 10-22-2007, 06:33 PM
rocketman121
I dont plan on reusing the a/c hoses. I just took them with me instead of completely removing the a/c fittings. Because the a/c fittings were already at a 90 angle.
Ill remove the a/c fittings, then are the connections on the actual compressor standard?
The inline oiler and inline filter I bought have 3/4NPT on one side and 1/4NPT on the other. So yes, I need to go from the compressor to 3/4NPT, then the output is reduced down to 1/4NPT. Maybe this will make more sense.
air filter - 1/4NPT - OILER - 3/4NPT - 90*elbow - compressor
compressor - 90*elbow - 3/4NPT - FILTER - 1/4NPT - manifold etc.
post #52 of 297 Old 10-22-2007, 08:15 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
Ah yes i gotcha now, it probably would be easiest to use the A/C fittings like you said, since theyre already 90 degrees. If you take the the the A/C fittings off the copressor the ports are 3/4 NPT threads. And wow, i didnt think you could get an inline oiler with such a big end on it. The adapter you need will probably be in the pipe section, not the air section. Have you looked through all the black pipe fittings yet? I got a 3/4 NPT to 3/8 for my compressor, so you should be able to find one that goes to your a/c fitting.
post #53 of 297 Old 10-22-2007, 08:19 PM
hacked96
Don't put the inline oiler, air filter or anything plastic directly to the compressor, it will melt under heavy use.
hacked96 is offline
post #54 of 297 Old 10-22-2007, 08:46 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
I have the oiler, which has metal ends and a plastic body right on the compressor. I havent had any issues and have used it heavily. The intake gets warm because of the heat the compressor generates, but not nearly as much as the output and i think an oiler will be okay there.
post #55 of 297 Old 10-22-2007, 08:47 PM
rocketman121
I dont believe the oiler would get hot enough to melt. Its just sucking in air thru a filter.
Im more worried about the inline filter, which is why im running a 3-4 foot brass or braided steel hose from the compressor.
If it does melt, ill just fab up a metal bowl. The oiler/filter combo was only 15 bucks at harbor freight.
post #56 of 297 Old 10-23-2007, 04:57 AM Thread Starter
RussoGuitar
1989 XJ Cherokee
3-4 foot will work great, and will get rid of a lot the heat espicially if you use copper tubing. If you do have a problem with the filter, (i assume youre talking about the filter on the output), i got the Kobalt filter from lowes. Its got a metal top and the bowl is glass and its held up fine. 11 dollars...
post #57 of 297 Old 10-23-2007, 08:22 AM
joshs1ofakindxj
using a regular tool oiler isnt suffiecient for the sanden compressor. you need a MIST LUBRICATOR to ensure that the correct amount of oil is going through.
joshs1ofakindxj is offline
post #58 of 297 Old 10-23-2007, 09:58 AM
rocketman121
Ya, ya I've heard that. But i scored both the oiler and filter for 15 bucks total. I'm not spending upwards of 40-60 dollars just for a mist oiler. I dont/wont use the OBA system that often.
post #59 of 297 Old 10-23-2007, 02:56 PM
hacked96
Putting the dryer as far away from the compressor is best. A compressor pumps hot air loaded with evaporated water which small cheap dryers don't pick up.Distance between the compressor and the dryer allows the air to cool and the moisture to condensate inside the line and get picked up by the dryer as water. Otherwise the hot air loaded with evaporated water blows straight through the dryer and condensates in your air hose which spews water. My airline snakes all the way through to the back of the vehicle with the filter right at the air hose connector just like you would see in a shop, no moisture at all.
hacked96 is offline
post #60 of 297 Old 10-24-2007, 11:18 AM
Jonny7
1990 XJ Cherokee
RussoGuitar
What type of material are your red hoses made of (rubber, pvc)? Did you just buy a 50 ft. air hose and cut that up?
What type of oil are you using in the inline oiler to lubricate the compressor? How do you know how much oil the inline oiler is putting out and if it is enough for the compressor?
Jonny7 is offline
ac , ac to oba , compressor , conversion , oba conversion , sanden , xj
ZJ Rear Disc Conversion to 8.25" Write Up - The Whole Truth!!! TPI Monte SS XJ Cherokee Technical Forum 47 08-21-2013 09:34 AM
LED Panel Lights Conversion Write-up Islandroaddie96 XJ Cherokee Technical Forum 24 06-13-2011 05:50 AM
waggy front conversion write up? T4STE XJ Cherokee Technical Forum 9 01-12-2007 08:57 AM
8.25 rear disc conversion - Write up AMK XJ Cherokee Technical Forum 5 08-05-2004 10:00 AM
8.25 rear disc conversion - Pics & Write up soon AMK XJ Cherokee Technical Forum 12 08-04-2004 05:15 PM
