A/C to OBA conversion write up -PICS - Page 2 - JeepForum.com
post #16 of 297 Old 10-10-2007, 09:29 AM
242much
2009 JK Wrangler
very cool mod.
"The stoke was palpable..."
good grief, just buy the Rubicon.
242much is offline
post #17 of 297 Old 10-10-2007, 11:15 AM
JRusso96
nice- very cool
JRusso96 is offline
post #18 of 297 Old 10-10-2007, 04:46 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
Thanks guys.. as for parts, i may miss a couple things but here are the basics:
1.A/C compressor (obviously)
2.About 30 feet of 3/8th air hose
3.Air filter
4.Lots of 1/4 NPT to 3/8 hose barb fittings.
5.Inline air tool oiler
6.Check valve.
7.Air manifold
8.Saftey reliefe valve
9.Pressure switch
10.Tank
11.Oil recovery filter
12.Hose quick connects and other fittings
13. switch.
RussoGuitar is offline
post #19 of 297 Old 10-11-2007, 12:04 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
In case anyones interested inflation time from 2psi to 32 psi was 45 seconds with two breaks to check pressure. Tire was a 33x12.50x15
post #20 of 297 Old 10-11-2007, 12:30 PM
97tjtom
THIS SHOULD BE A STICKY!!!!
im really glad you did a writeup on this as this is EXACTLY what ive been looking for!
Current: 1999 TJ 4.0 5 Speed
Past: 1999 XJ 4.0 Auto, 1993 XJ 4.0 5 Speed, 1997 TJ 4.0 5 Speed, 1994 XJ 4.0 5 Speed, 1993 Cadillac Sedan Deville 4.9L V8, 1991 Isuzu TrooperII 2.8L 5 Speed
97tjtom is offline
post #21 of 297 Old 10-11-2007, 03:51 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
great, glad it was usefull to someone,
post #22 of 297 Old 10-11-2007, 03:56 PM
XJohnnyC
XJohnnyC's Avatar
Nice writeup. I just completed my York OBA setup, so that I can retain my factory A/C. And I mounted my 2.5 gal Viair tank in the exact same spot as you.
There's a little more work involved, like re-routing the A/C lines, moving the battery to the other side, and spacing out the clutch fan to clear the York pulley.
Kilby's website has a lot of good info, such as diagrams and parts lists, that I used to piece my setup together.
www.kilbyenterprises.com
XJohnnyC is offline
post #23 of 297 Old 10-11-2007, 06:35 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
Yeah i considered the york, but this was cheaper and easier, since i already had the compressor mounted and, and i dont have much room for another compressor. The york is a great way to go though, espicially if you want to keep the A/C. Kilby does have a nice website and products, though there stuff i a bit pricey. Im real happy with their pressure switch though.
post #24 of 297 Old 10-13-2007, 04:58 PM
XJohnnyC
XJohnnyC's Avatar
Not to rain on anyone's parade or anything....
But I was talking about this thread to a mechanic buddy of mine. He says the Sanden is not a good compressor to use for OBA. He has seen people do this mod and have the compressor seize up on them. Something to do with the oiling system.
He has seen someone go through three Sandens, and they all seized up after a short period of time.
Hopefully, these are exceptions and not the rule. Let us know how your setup works out, RussoGuitar.
XJohnnyC is offline
post #25 of 297 Old 10-15-2007, 03:00 PM
RuffedUpXJ
RuffedUpXJ's Avatar
1988 XJ Cherokee
Well they probably dont have an oiler inline like Russ has.
ALso anyone know a quick way to check if my compressor works?
88 XJ Red
| 5" of lift | Custom Bumpers | Black Rockcrawlers with 35x12.50 BFG MT's | Custom Rock Rails | Homebrewed OBA | Custom Roof Rack Loaded | Tube Doors |
Play 4x4Country.
RuffedUpXJ is offline
post #26 of 297 Old 10-15-2007, 04:09 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
Ive been running the air system very hard lately and its been doing awsome. I couldnt be happier with it. The inline oiler seems to be doing its job because the recovery bottle filter has been collecting oil in it so i know the compressor is getting lubricated. Ill keep you guys updated though if any failures occur. And Ruffedup, just disconnect the wire going to the compressor clutch and run a small jumper wire from it to the battery. If the clutch engages then the clutch is good, youll here it click. YOu can do this with the engine running to make sure the comp isnt seized.
post #27 of 297 Old 10-15-2007, 05:51 PM
RuffedUpXJ
RuffedUpXJ's Avatar
1988 XJ Cherokee
Well I was wondering if does that I know that my clutch works but I mean any quick ways to check and make sure the compressor actually compresses and isnt worn out
88 XJ Red
Play 4x4Country.
post #28 of 297 Old 10-15-2007, 06:23 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
You could disconnect the A/C lines, and then you can either turn it over by hand, (which obviously youd have to take the belt off) or start it up and engage the clutch, and just check for good suction/output. Id do it by hand... And im not responsible if you hurt your self doing this Chances are its probably fine.
post #29 of 297 Old 10-15-2007, 07:09 PM
RuffedUpXJ
RuffedUpXJ's Avatar
1988 XJ Cherokee
Ok sweet thanks.
88 XJ Red
Play 4x4Country.
post #30 of 297 Old 10-19-2007, 02:16 PM
Dickydubs
BUMP for sticky
Great write up! I'm debating doing this or using my CO2 tank from my kegerator system that I'm not currently using. BUMP FOR addition to the STICKY
97 sport 4.0 5spd, command trac
stock height with General Grabber AT2
sony HU w/ aux input, infinity 5 1/4" and 6x9"
Dickydubs is offline
ac , ac to oba , compressor , conversion , oba conversion , sanden , xj
ZJ Rear Disc Conversion to 8.25" Write Up - The Whole Truth!!! TPI Monte SS XJ Cherokee Technical Forum 47 08-21-2013 09:34 AM
LED Panel Lights Conversion Write-up Islandroaddie96 XJ Cherokee Technical Forum 24 06-13-2011 05:50 AM
waggy front conversion write up? T4STE XJ Cherokee Technical Forum 9 01-12-2007 08:57 AM
8.25 rear disc conversion - Write up AMK XJ Cherokee Technical Forum 5 08-05-2004 10:00 AM
8.25 rear disc conversion - Pics & Write up soon AMK XJ Cherokee Technical Forum 12 08-04-2004 05:15 PM
