A/C to OBA conversion write up -PICS - Page 16 - JeepForum.com
post #226 of 297 Old 07-08-2013, 11:29 AM
99_TJ_Wyoming
My 99 also doesn't have a/c, no controls and no compressor.
99_TJ_Wyoming is offline
post #227 of 297 Old 07-08-2013, 11:40 AM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
I'd love to see pictures. I spent $40 for a bypass pulley when I yanked my AC compressor.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #228 of 297 Old 07-17-2013, 11:29 AM
ColdWarrior
1991 XJ Cherokee
This write up was AWESOME. Here's shots of my take on it.
Got all the pieces for the OBA...except the damn solenoid.
Got a manifold all pieced together. But I needed a place to put it under the hood and a way to mount. Found this T bracket at my local hardware store.
The manifold had one port in the rear and I used a 'flush' plug to close it. There was enough threads hanging out I could use the brass cap to attach it to the bracket.
Cut a piece of metal to mock up the bends I would need to make to the bracket,
Next I made sure my system was empty. Then I removed the original AC lines from the back of the compressor. I also tested the clutch prior to all this by running a hot wire from the positive terminal to the single wire going into the AC compressor.
Started off on the intake side. Some blue monster tape and a pipe reducers and an inline air tool oiler. On the AC system the Freon lubricates the compressor, the oiler draws tool oil straight into the compressor.
Then came the swing check valve. This has a swinging gate valve (Controlled by gravity) that keeps the air from flowing back into the compressor from the system and tank. Make sure you get one that has ALL metal internals. The air coming out of the compressor for about the first couple feet is over 200 degrees.
Next comes the inline filter (draws out water and small debris). I didn't want it to hang unsupported on the hoses, so I needed something to make a bracket out of. Viola......a metal bookend.
Cut it, then mount it with a nut/bolt. Ziptie the filter to the new bracket.
Then slide the hose over the barb fittings on the compressor, filter in and out and the manifold. I used High Heat Silicone hose (again the first 2 feet of air is HOT) for this part, along with crush clamps.
Then I ran an intake line around behind the cooling bottle and up along the inner fender. Still waiting on my mini intake filter.
Im planning on running air ports front and rear, plus my airhorns. Stared off by running the front line down the inner fender on the passenger side, and down behind the battery tray to under the headlight. There I T'd off, one direction for the air chuck, the other towards the airhorn solenoid.
Then used a self tapper and loop to stabilize the T.
Ran airline from the open part of the T to the new 12v solenoid that showed up. Used more self tappers to mount it to the front facia under the temp sensor.
As you can see above I grounded it to the frame, then ran the other side over to my stock horn lead. I cut the end of the lead off and then used 'solder seals' to bind the three way connection together. These things are spendy, but so worth if for a weather tight soldered connection.
Wired and tucked it all into the loom.
Then I connected everything to the pressure switch using 'perma seal' female spades, taped it all up and tucked it away.
I ran the rear airline down behind the brake booster and ziptied it to the brakelines all the way to the rear, then brought it up and behind the driver side tail light housing. I will probably redo this by drilling and using water tight grommets and silicone. I don't like the way it pushes the light housing out.
I pulled out the inner trim and ran the hose through.
The tank would fit perfectly....but only if I got rid of the base of the spare tire bracket. So I pulled the bracket and secured the tank hook. Gonna band the body of the tank to the upper spare tire bracket with heavy metal lined zip tie.
Hang the tank. Note the other second hole in the panel. I will be running a second line out of the tank to an airchuck under the rear bumper, but I ran out of airline.
Plugged the extra hole.
ColdWarrior is offline
post #229 of 297 Old 07-17-2013, 09:46 PM
Hudson
Just got my front quick disconnect in. I didn't like the idea of just letting the quick disconnect dangle on the rubber hose so i went overboard and secured it. Custom brackets and some other shenanigans. These pictures should show it better.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #230 of 297 Old 07-18-2013, 12:13 AM
ColdWarrior
1991 XJ Cherokee
Now that's pretty damn epic.
post #231 of 297 Old 07-30-2013, 02:16 PM
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Sweet! Awesome right up!
My Jeep Build!
Nik-Nak is offline
post #232 of 297 Old 07-30-2013, 03:23 PM
dave564
Hudson, what did you do to filter the intake air?
I am planning on board air in the future, I plan to use the engine air box for a filtered source like we do on tractor trailers.
dave564 is offline
post #233 of 297 Old 08-17-2013, 11:41 PM
Hudson
Sorry for the delayed response. Didn't see your post.
Here's a picture of my setup. Totally overboard i know.
Hudson is offline
post #234 of 297 Old 09-13-2013, 12:36 PM
Elexwiz
1987 XJ Cherokee
I don't think it's overboard. I think it's smart. You made a one piece module that can be quickly and easily removed to clean the filter or to just get it out of the way for other repairs. Nice work!
1987 XJ 4.0 I6, Peugeot tranny, NP231, AA SYE, 8.25" 29 spline, Dana 30 (HP), Rusty’s 4.5 inch coils, BDS 5500 4.5" shocks, 5" junkyard bastard pack, Rusty’s Adj LCAs, RC Quick Discos, JKS BPEs (front and rear), Aussie Lockers (front and rear), Durango steering box, and Removable Doors!
Elexwiz is offline
post #235 of 297 Old 07-30-2014, 06:15 PM
DaveS01
Im bringing this thread back from the dead...
Could someone make a parts list of things I can order off amazon?
Im ready to start this project, but have never dealt with pneumatic setups like this...and really need some help on exactly what I need.
DaveS01 is offline
post #236 of 297 Old 09-29-2014, 07:26 PM
petertom13
Excited about doing this conversion, as a fireman, I was wanting to do something tied in with that, hoping to find a decommisioned carbon fiber SCBA tank, have that kick *** look.
petertom13 is offline
post #237 of 297 Old 09-29-2014, 07:50 PM
austin6137
1990 XJ Cherokee
I used and aluminum scuba tank,
Don't mind the cheapo subs lol
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #238 of 297 Old 10-07-2014, 04:42 PM
petertom13
[QUOTE=austin6137;25808266]I used and aluminum scuba tank,
Attachment 1631738
Looks good, got fire chief looking for me, he deals with equipment as well. Shouldn't be to hard to find an old SCBA tank, been collecting parts from work as well (mostly pneumatic manufacturing) they throw out a lot of good items, I should be able to do this conversion without too much money spent. Thinking just the inline oiler, cleanout, and high temp hose should be only items I need to purchase.
Herky - '95 with a 6 banger and stock drivetrain
post #239 of 297 Old 10-07-2014, 04:50 PM
petertom13
Forgot to ask this question, not sure if many are still following this thread, but has anyone put a quick release on their tank, and mounted them so that they could be removed and used as a bubble? I'm thinking I'm going to mount mine on my passenger rear fender, but I'm hoping to mount it in a way that I can use it as a portable bubble, if needed.
post #240 of 297 Old 10-09-2014, 05:24 AM
Trainhop91
Originally Posted by austin6137
I used and aluminum scuba tank, Don't mind the cheapo subs lol
I've found a couple scuba tanks on Craigslist for 20 bucks a piece. Was wondering how you set yours up to use as a tank?
Anyway this would be able to be ran without a tank? Or would it not have enough pressure unless built up.
Trainhop91 is offline
ac , ac to oba , compressor , conversion , oba conversion , sanden , xj
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
ZJ Rear Disc Conversion to 8.25" Write Up - The Whole Truth!!! TPI Monte SS XJ Cherokee Technical Forum 47 08-21-2013 09:34 AM
LED Panel Lights Conversion Write-up Islandroaddie96 XJ Cherokee Technical Forum 24 06-13-2011 05:50 AM
waggy front conversion write up? T4STE XJ Cherokee Technical Forum 9 01-12-2007 08:57 AM
8.25 rear disc conversion - Write up AMK XJ Cherokee Technical Forum 5 08-05-2004 10:00 AM
8.25 rear disc conversion - Pics & Write up soon AMK XJ Cherokee Technical Forum 12 08-04-2004 05:15 PM
