A/C to OBA conversion write up -PICS - Page 13 - JeepForum.com
post #181 of 297 Old 03-11-2010, 03:02 PM
Mickey_D
And to give another comparison, my Sanden gets used probably 10-15 hours a month (of compressor run time). So I'm up around 60-75 hours of it going. This is without any sort of oiler or inlet filter (I have 2 spare compressors, not worried about it). Today it FINALLY started making some ticking and clicking noises that I'm willing to bet are valves or rings worn out.
So figuring if you go wheeling once a month and use it to air your tires up (10 minutes of compressor run time), there is no reason in the world why you shouldn't get minimum of 10 years of use out of it (using my example it works out to 45 years).
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #182 of 297 Old 03-11-2010, 06:00 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Awesome write up.
If I may thread jack a bit, do you have any interference issues with those battery terminals? I've wanted to use a set of those for awhile, but wasn't sure if the positive would touch the hood and short out.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #183 of 297 Old 03-11-2010, 09:14 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
Originally Posted by dagr8tim View Post
Awesome write up.
No not until a ran a bigger battery, but i did use terminal covers to be safe. I've since relocated the battery and used a junction block to cut down on the number of cables going to the posts.
RussoGuitar is offline
post #184 of 297 Old 04-05-2010, 09:50 PM
matthewh_1
Awesome write up, just finished my conversion, this thread was a big help. One question though, is your compressor fairly audible when engaged? I ask because I can definitely hear mine when it turns on, and my oiler is probably about 4 feet back from the compressor, so I'm just wondering if the compressor is being properly lubricated.
National Topless Day 2010 winner!
Zombie Outbreak Response Unit #70
Originally Posted by jclauson View Post
When a girl tells you your flex is sexy then you are doing something right in life.
matthewh_1 is offline
post #185 of 297 Old 05-02-2010, 03:34 PM
1993sahara
is there anyway i could get a picture of the wiring at the ac pump? i dont know how to do it. one wire looks like it is a ground and the other wire goes into the pump
93 Sahara 4.0, ax15, BDS 2 inch springs, MORE greasable 5/8hd shackles, Ford 8.8 rear, AA sye, Quigley cv shaft, 32" wrangler mtr with Kevlar
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
1993sahara is offline
post #186 of 297 Old 05-08-2010, 10:54 AM
matthewh_1
You leave the ground wire the way it is, and bring power to the other wire.
post #187 of 297 Old 10-01-2010, 09:36 PM
bigred92
Would you be able to tell me the exact make and where you got the pressure switch and the oiler?
bigred92 is offline
post #188 of 297 Old 12-13-2010, 01:32 AM
crouch_104
1989 XJ Cherokee
deffinatly goin to do this tthanks
crouch_104 is offline
post #189 of 297 Old 12-13-2010, 07:51 AM
40vern
i am new to this sight
however i did this project to my yota with the 22r last month. i was surprised at how good it works.
i think that i will like this sight allot of information
40vern is offline
post #190 of 297 Old 02-18-2011, 11:41 PM
phillies4752
phillies4752's Avatar
awesome build! I plan on doing this on my Wrangler as soon as the money rolls around
phillies4752 is offline
post #191 of 297 Old 03-02-2011, 11:23 PM
gretsch921
Yess this just answered so many questions of mine... who needs ac when you can take your top off anyways...
gretsch921 is offline
post #192 of 297 Old 04-06-2011, 02:09 PM
ThomasYJ
you know youve got it bad when you wake up and you're first thought is "i wonder how to convert my A/C to OBA." ESPECIALLY when you hadn't been thinking about it previously!
Like everyone else has said, This is by far probably the best write up on here. I've looked at others but it seemed to be too complicated, but this has spelled out most of it. still a little fuzzy on the manifold part but im sure ill figure it out as i go. I think I've got the switch issue down. One point that was brought up, by Mickey_D i believe, was that of a thumb throttle for the compressor. How in the world would that be incorporated?
Props to everyone who contributed.
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #193 of 297 Old 04-06-2011, 02:12 PM
ThomasYJ
OH,, also forgot to ask
Russo, in your install pic, that black cylindrical component IIRC to the right of a white overflow tank, is that your inline oiler??
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #194 of 297 Old 04-06-2011, 05:30 PM
4LarXedo4
^ Thumb throttle to keep the rpm steadily raised, speeds up compressor fill rate. That way you don't have to wait so long in between tire fill ups and etc.
IG: YJ4Point2
HEMI Club Member #48
4LarXedo4 is offline
post #195 of 297 Old 04-06-2011, 06:32 PM
justanotherjpr
Thanks for posting this. Fantastic ideas. Anyone have more details on how to do this with a york or another stock compressor and keep the AC?
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
ac , ac to oba , compressor , conversion , oba conversion , sanden , xj
ZJ Rear Disc Conversion to 8.25" Write Up - The Whole Truth!!! TPI Monte SS XJ Cherokee Technical Forum 47 08-21-2013 10:34 AM
LED Panel Lights Conversion Write-up Islandroaddie96 XJ Cherokee Technical Forum 24 06-13-2011 06:50 AM
waggy front conversion write up? T4STE XJ Cherokee Technical Forum 9 01-12-2007 09:57 AM
8.25 rear disc conversion - Write up AMK XJ Cherokee Technical Forum 5 08-05-2004 11:00 AM
8.25 rear disc conversion - Pics & Write up soon AMK XJ Cherokee Technical Forum 12 08-04-2004 06:15 PM
