A/C not working - JeepForum.com
post #1 of 10 Old 08-14-2013, 07:05 AM Thread Starter
99_XJ_
A/C not working
I recently replaced my A/C clutch and compressor but now there is no A/C and no heat. I checked the clutch and its spinning, the compressor is on, and the lines are cold so there's freon in the lines, and I checked the fuse panel and they're all fine. Idk what else the problem could be...
99_XJ_ is offline
post #2 of 10 Old 08-15-2013, 07:32 PM
1CleanTJ
1CleanTJ's Avatar
you say no a/c and no heat. is your fan speeds working ? do you feel air blowing out of the dash vents ? you say you changed the compressor, did you bring it to a shop to have the a/c recharged ?
<-- CLICK !!! AND SHARE
1CleanTJ is offline
post #3 of 10 Old 08-16-2013, 07:26 AM Thread Starter
99_XJ_
no fan speeds working at all and there is minimal air coming out of the vents and I had it recharged too... I had a friend tell me it could be the resistor but idk...
99_XJ_ is offline
post #4 of 10 Old 08-16-2013, 04:01 PM
psychoteen101
sounds like the blower motor resistor is bad, common on jeeps. Or could be a bad blower motor. Id test/replace the resistor first.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #5 of 10 Old 08-16-2013, 05:56 PM
1CleanTJ
1CleanTJ's Avatar
sounds like a bad fuse or blower motor. although blower motor resistors do get corroded and go bad, usually you will have high still. you can start by checking it though, its accessable under the passenger dash. the blower motor can be pulled out from under the hood, on the passenger side firewall, 3 or 4 bolts hold it in
1CleanTJ is offline
post #6 of 10 Old 08-16-2013, 08:43 PM
CCKen
CCKen's Avatar
Here's a shematic of the blower motor circuit. Note the fuse.
CCKen is offline
post #7 of 10 Old 08-19-2013, 12:55 PM Thread Starter
99_XJ_
how would i go about testing to see if there is orient a problem with the motor/resistor?
99_XJ_ is offline
post #8 of 10 Old 08-19-2013, 07:05 PM
AZ Jeff
2014 JK Wrangler
You say "no heat" and "no A/C". I assume you really mean the blower that pushes air through the heater box is not working. Am I correct?
If so, check the two fuses noted by others in the schematic they posted.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #9 of 10 Old 08-20-2013, 07:19 AM Thread Starter
99_XJ_
I checked the fuses and they weren't blown how would I check to see if the motor is blown?
99_XJ_ is offline
post #10 of 10 Old 08-20-2013, 07:46 AM
AZ Jeff
2014 JK Wrangler
Do you own a VOM? If not, you can pick one up for about $15 at Radio Shack or most home improvement stores. Use that, along with the schematic posted above, and you can figure out where you loose the 12V that drives the blower motor.
AZ-Jeff
AZ Jeff is offline
a/c , broken , cherokee , jeep , xj
