A/C low pressure switch - JeepForum.com
post #1 of 3 Old 08-10-2013, 04:51 AM Thread Starter
jtcnj
My a/c compressor / clutch wasnt engaging intermittently, and then quit.
Jumping out the low pressure switch on the accumulator allows it to run.
I'm having trouble finding a replacement at my local Advance, AutoZone, Pep Boys because the part description calls it a pressure switch and doesn't specify the low or high side. The part I think is the right one is also described as a binary switch.
Can someone clarify this?
I'm pretty sure this is my only problem since the system appears normal with the switch jumpered out.
Put the guages on and:
Static pressure is about 75lbs, running high side pressure is 260, 300 when the elec fan comes on, and the low is about 34lbs. I think the ambient temp was about 82 deg F at the time. Both sides equalize quickly when shut off.
Its cold at the vents but I dont have a thermometer. I shot it with the infrared one, but it is giving me the plastic duct, not the air exiting the vents.
"Lay Down Sally" Silverstone Metallic 2001 xj sport 4.0L/AW4/231/8.25 mostly stock.
"Dubyuh" or "Blue Bayou": Patriot Blue 2001 Up-Country WJ Limited 4.7L V8 Quadra Drive: for now known as "Al-Dente" after my wife's "mod".
New Addition 12/2011: "Pearl" Forest Green Pearlcoat 1999 xj SE 4.0L/AW4/231/8.25 mostly stock for now.
____________________________________________
I didn't agree, but hoped for Hope and Change.
I got change for myself and my family: for the worse.
This is the reality of: Barackalypse Now. Again.
"The most terrifying words in the English language are: I'm from the government and I'm here to help."
Ronald Wilson Reagan
jtcnj is offline
post #2 of 3 Old 08-10-2013, 05:18 AM
jeepman788
Take a look at Jeep-Air.com
Lotza Jeep AC help and parts.
I never dealt with them but their info and parts lists might help.
jeepman788 is offline
post #3 of 3 Old 08-10-2013, 05:37 AM Thread Starter
jtcnj
I saw them, they dont list XJ parts. I realize the 4.0 is used in the TJ, ZJ and WJ, but I dont know if its the same because the ECUs may be different.
I may give them and the stealership a call if I don't get much action here.
jtcnj is offline
