Quantcast A/C Hub Issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > A/C Hub Issue
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 01-22-2008, 09:49 AM   #1
doctorcherokee
A/C Hub Issue
Hello,
I have a 1998 I6 Jeep Cherokee Sport. My Jeep started making crazy belt-grinding or slipping noises, and a couple days later I took it to a reputable mechanic.
Turns out it was the A/C hub assembly or something like that came off and the mechanic told me a new hub can't be warrantied (or something like that) and that the air compressor needed to be replaced. But, anyway, it's gonna cost $800.
I don't know if I have enough time or expertise to even try to tackle a problem like this, and I need my car back, so I've gotta get it done. What do you guys know about this? Could just the hub be replaced for cheap? Is it better to just replace the whole thing? Are there any other options?
Thanks so much for any input.
1998 Jeep Cherokee 4WD Sport 4.0L I6
doctorcherokee is offline   Reply With Quote
Old 01-22-2008, 12:49 PM   #2
tangofox007
Depends on exactly what the problem is. A new clutch assy costs almost as much as a complete compressor, but it can be replaced without opening the refrigeration portion of the system. If the problem is just the bearing, it can be replaced fairly easily, although finding the bearing can be a bit of a challenge for some of the later models.
But if the problem is just the bearing, there is no need to buy a new clutch, if you can find a replacement bearing.
Originally Posted by doctorcherokee
Turns out it was the A/C hub assembly or something like that came off and the mechanic told me a new hub can't be warrantied (or something like that)...
I really don't understand what that means.
tangofox007 is offline   Reply With Quote
Old 01-22-2008, 01:02 PM   #3
tangofox007
Another option would be to buy a new (or reman) compressor, then transfer the entire clutch assy to you old compressor. Then you would have a spare compressor, or you could sell it without the clutch.
The shop is probably going to charge you $600 for a compressor that you could buy yourself for less than half of that amount.
Old 01-22-2008, 01:05 PM   #4
dz1087
It's nothing you can't do as long as you don't need to get into the refrigeration.
Air Force Jeep Club - Tail# JF037AD
'03 TJ Sport, Black on White, Stock. [[Gone]]
'99 XJ, Purple, Stock but with new wheels.
Running Doorless? Check your state's Mirror Laws!!
http://www.jeepforum.com/forum/f176/list-state-mirror-laws-565361/
There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else.
Theodore Roosevelt
dz1087 is offline   Reply With Quote
Glock Forum
