A/c and heat - JeepForum.com
post #1 of 3 Old 09-25-2017, 06:41 PM Thread Starter
cl700
1989 XJ Cherokee
A/c and heat
So I知 looking to build a daily driver/ weekend warrior. I知 doing a custom dash up front and wondered if I知 removing my ac system if I could make the heater core box smaller and more efficient for just heat? Obliviously I would run new ducting and things. Just really need defrost and heat for up front. Not to worried about the back. I would be daily driving it till I get a back up vehicle. Just wondered what the options were?
Sent from my iPhone using Tapatalk
Ride like its your last
cl700 is offline
post #2 of 3 Old 09-25-2017, 09:57 PM
dented
I'm not quite sure what you are asking. The heater core doesn't do double duty so that is what it is. The box in the dash that holds the heater core and the a/c evaporation coil could be made smaller if you are eliminating the A/C. You would have less stuff to make space for in your custom build.
dented is offline
post #3 of 3 Old 09-25-2017, 11:28 PM Thread Starter
cl700
1989 XJ Cherokee
Well I read somewhere that you had to keep certain things in place for the heater to work properly( meaning keep the a/c coil in place) and mainly looking for help on what kind of ducting to run, and what would be the best materials to make the new box out of. Best way to go about making new switches and things of this nature. Mainly looking for help from someone who maybe has done this sort of thing or has the mind to be able to.
cl700 is offline
