A/C drops voltage... why? - JeepForum.com
post #1 of 8 Old 08-20-2008, 03:39 PM Thread Starter
remi
1994 XJ Cherokee
Hey, I have noticed that when I kick on my A/C, my voltage drops from 13.8 to 12.4... I was curious if this is normal or is something wrong. My A/C blows COLD air, just like new. I know my running voltages because I have a radar detector with voltage meter built in as well as my dash has the voltage meter on it. There is a power lost too. It's not a big power lost, but it's noticable. What could cause this. Thank you in advance.
Remi
PS - I did try searching the forum here but couldn't seem to find anything. Maybe a point in the right direction.
remi is offline
post #2 of 8 Old 08-20-2008, 04:14 PM
diskman_1
1992 XJ Cherokee
Maybe the electric radiator fan is drawing too much juice? With the engine off and cooled down, spin the electric fan by hand. It should spin with a little drag. Is it's really difficult to turn then there's the problem maybe.
Just my .02
diskman_1 is offline
post #3 of 8 Old 08-20-2008, 04:21 PM
kadetklapp
1997 XJ Cherokee
Normal. Not only does the compressor slow the engine down (thus slowing the alternator) but it also kicks the aux fan on which draws a fair amount of amps itself.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #4 of 8 Old 08-20-2008, 04:30 PM Thread Starter
remi
1994 XJ Cherokee
Ehh. My fan turns perfectly fine. I am just not use to having the A/C on the Jeep, not working anyways. That and my other cars didn't show more than a -.2 voltage drop.
remi is offline
post #5 of 8 Old 08-20-2008, 09:55 PM
rokrazy
1990 XJ Cherokee
My jeep does the same thing, also when i turn the heater on
rokrazy is offline
post #6 of 8 Old 08-20-2008, 10:05 PM
arkieoscar
1995 XJ Cherokee
Mine too. The battery is probably seeing higher voltage than what the gauges read. The voltage drop will almost all be from the fans. The compressor will reduce the power available to the trans. but won't slow the alternator as the engine speed is controlled by your foot except at idle where the computer keeps it from dropping.
arkieoscar is offline
post #7 of 8 Old 08-21-2008, 09:11 AM
sundevilkid
sundevilkid's Avatar
I think everyone's does this. The voltage reading is showing voltage after draw. So your battery should still be seeing 13.5 volts, even though your cigarrette lighter only shows 12.4.
The blower has a lot of draw as does the e-fan. If you switch it from a/c to vent, my voltage drop is usually just a little better, but that's because the a/c clutch doesn't kick in, and the e-fan doesn't turn on. But that blower is turning away, so I've always just blamed the blower motor. It's not bad, just power hungry.
1996 XJ Classic
My sig got too long. So we'll just say it's Friggin' Sick.
sundevilkid is offline
post #8 of 8 Old 08-25-2008, 09:30 PM Thread Starter
remi
1994 XJ Cherokee
Hey, found the problem. It's the blower. The A/C only drops it by .2 volts. Blower drops it from 13.4(+/-) to as low as 11.8 volts.
remi is offline
RPM drops around 85-95 km scott050 XJ Cherokee Technical Forum 6 08-10-2009 02:20 PM
RPM Drops mudrunnerxj XJ Cherokee Technical Forum 2 06-08-2008 09:55 AM
Voltage Drops To Low With Blower Fan And Lights On... E55&98 Jeep XJ Cherokee Technical Forum 2 09-26-2007 04:43 PM
cluster voltage gauge showing wrong voltage. BackDraft XJ Cherokee Technical Forum 7 03-12-2005 02:44 PM
Amp meter drops to zero! XJCrazyMA XJ Cherokee Technical Forum 5 08-20-2004 11:49 AM
